First post, by Quadko
- Newbie
I thought I remembered a conf setting to do this (like SwapUVAxes), but I'm not coming up with it in search, and maybe I misunderstood or misremember.
Is there a way to tell dosbox to use the XBox 360 (or similar)'s right stick X axis as the Joy2 X axis, instead of the default trigger/throttle keys?
I tried with my 5 axis Thrustmaster HOTAS USB, and it has an unused axis I can't swap in, either, though as they are all throttle and rotation axes the default setup works OK. (In windows gamepad properties, the 360's throttle triggers are the Z axis and the right stick is X & Y rotation axis, in case that detail helps anyone.)
I'm in Win7 if it matters. And I've got a Sabrent gamepad that works, I just like 360 controller better and would love the option. Any options? 😀
