First post, by BigBodZod
So I have the following GPU in my gaming rig:
http://www.gigabyte.com/products/product-page … spx?pid=4290#ov
It's a triple fan configuration but the center fan is failing, it looks to be one of the frameless type, about 70 ~ 80 mm I think.
Anybody know if there are replacement fans or GPU heatsink/fan combination ?
Since the GPU is out of warranty it doesn't matter if I swap out the GPU cooler or the faulty fan at this point.
I also found this interesting GPU Cooler Replacement as well, looks like Newegg carries it too.
No matter where you go, there you are...
