First post, by ja524
Hi, I have a new iMac that is 21.5". I am trying to play champ manager 9798 via dos box. It launches & plays absolutely fine, apart from an inch of black band down either side of the screen. Obvioulsy I need to change the resolution, but no matter what I change in the config file, I cant get it to widen. the height is ok. If I make the windows resolution 1920x1080, it just makes that full screem version of the game smaller!
Any help would be much appreciated
Many thanks
Reply 1 of 5, by ripa
You need to use a 4:3 resolution in Dosbox, and configure your iMac to stretch the picture. For example:
fullscreen=true
fullresolution=1440x1080 # alternatively you can try 1024x768, 800x600, etc.
aspect=true
edit: also output= setting affects things. Last time I tried Dosbox on a Mac, I used output=opengl
Reply 2 of 5, by ja524
Hi, many thanks for replying.
When you say "you need to use a 4:3" etc....do you mean the following commands will achieve this
fullscreen=true
aspect=true
im also getting the same results on windows laptop at work. If I key in the 1440x1080, it doesnt even launch the game. If I key in 1024x768 it looks like the same issue (attached is a screenshot), where theres black bands down the side of the screen.
Thanks
Reply 3 of 5, by ripa
If you set your Windows laptop or iMac desktop to 1024x768, what happens? Do you have black bars on the sides or is the picture stretched to full width?
Reply 4 of 5, by SquallStrife
Many thanks
That's normal. The game is not designed to run widescreen. If it filled the screen, the picture would be stretched out of proportion. Things that are meant to be square would become rectangular, things that are meant to be circles will become ovals. Make sense?
Reply 5 of 5, by bangingthedrum
I'm completely new to dosbox but I'm having problems with this game as well. I'm trying to run it on windows 8.1, but every time I launch the game, it loads, but the only colours it is showing up in is pink, black, blue and grey, and isn't playable at all. I've tried playing about with a few of the settings but nothing seems to make any difference. If somebody could point me in the right direction I'd appreciate it greatly.
