First post, by CaelThunderwing
i have an old midwest Micro Eletie system (486-33 Cyrix CPU) i've manage dto max it out on all teh ram the board can take, (20MB)
i've tried QEMMit works... Almost, i notice signifcant slowdown sin thinsg that wernt before, (strange eh?) i can play the game i needed a memmory manager for, (The Adventures of Willy Beamish) but Epic Pinball? causes the system to crash and QEMM to report a crash,
"Exception # 6 at 0AA8:0000, error code 0000"
i never really did mess w/ multiboot on a system this old or early systems in thier day, i never needed to, but how can i go about multiple boot setups w/ Dos and some memorymanager just so i can squeeze every bit of Conventional memory [ theres a a requirement on that for whatever reason on Willy Beamish ] and one for Windows 3.11 so it has full 20MB of ram for use?
Reply 1 of 9, by kixs
Not many games need more then 600KB of conventional memory. Are you trying to run from pure DOS or from within Windows? It also depends what drivers are you loading via config.sys and autoexec.bat.
But 20MB or more memory usually won't give you more conventional memory . Problematic is memory under 1MB and this is where memory managers come handy. I only use EMM386 when I need to. I only load necessery drivers and have more then 600KB of low memory in any case.
Reply 2 of 9, by bjt
Switching the processor into V86 mode does incur a noticeable performance penalty on 386 & slower 486 systems.
Reply 3 of 9, by PeterLI
Reply 4 of 9, by CaelThunderwing
sorry for that atm i've managed (having tried pc dos 2000) to get 559kb Conventional memory using UDVD2 + SHCDX33F (if i unload shcdx33f i have 566kb) any ideas to further optimize?
Autoexec:
SET BLASTER=A240 I2 D0 T4
SET GALAXY=A240 I2 D0 K11 P530 T6
SET SOUND=C:\SGBAS16
C:\WINDOWS\SMARTDRV.EXE
@ECHO OFF
SET PATH=C:\WINDOWS;C:\DOS;%PATH%
SET TEMP=C:\DOS
C:\DOS\DOSKEY.COM
c:\cdrom\shcdx33f.com /D:UDVD1
Config.sys
DEVICE=C:\WINDOWS\SMARTDRV.EXE /DOUBLE_BUFFER
DEVICE=C:\SGBAS16\DRIVERS\EEPROM.SYS
FILES=60
BUFFERS=10
dos=high
device=C:\DOS\HIMEM.SYS
device=c:\dos\emm386.exe ram x=a000-b0ff i=b100-b7ff x=b800-c7ff i=c800-d2ff x=d300-d3ff i=d400-efff x=f000-f7ff h=64 a=7 d=64
DEVICEHIGH=C:\DOS\SETVER.EXE
LASTDRIVE=G
DEVICEHIGH=C:\CDROM\UDVD2.SYS /H
DEVICEHIGH=C:\WINDOWS\IFSHLP.SYS
STACKS=9,256
(i use windows 3.11 for a few select games (simcity classic for windows, simtower, oddballz and dos for the rest of my games, but most of the games im pushing for as much conventional memory possible are Epic Pinball [needs 560kb] & The Adventures of Willy Beamish [which since was designed around early 286 machines, i guess needs 512kb Conventional memory] )
Reply 5 of 9, by PhilsComputerLab
I use a simple boot menu that allows me to select what memory options I need. I made a video tutorial here: http://youtu.be/cIEq2hMUYhA
The menu and drivers can be downloaded from my website. I haven't come across a game that doesn't run...
Reply 6 of 9, by PeterLI
Reply 7 of 9, by PhilsComputerLab
^^ Simple start-up files = simple life 🤣
Reply 8 of 9, by kixs
This are memory optimised config.sys and autoexec.bat
dos=high,umb
devicehigh=c:\dos\emm386.exe ram noems
DEVICEHIGH=C:\WINDOWS\SMARTDRV.EXE /DOUBLE_BUFFER
DEVICEHIGH=C:\SGBAS16\DRIVERS\EEPROM.SYS
LASTDRIVE=G
STACKS=9,256
FILES=60
BUFFERS=10
@ECHO OFF
SET TEMP=C:\DOS
lh C:\WINDOWS\SMARTDRV.EXE 1024
lh c:\cdrom\shcdx33f.com /D:UDVD1
lh C:\DOS\DOSKEY.COM
Use it and report what does MEM show.
Reply 9 of 9, by Jorpho
Have you considered reading the documentation that comes with Epic Pinball? 😒 (It's the file named HELPME.DOC.)
To run this game under Windows, be sure to run the file "PINBALL.PIF" (not
the file "PINBALL.EXE"). This should would very reliably under Windows on
nearly all computers.
Also, many games in particular usually advised disabling "stealth mode" for QEMM, though I don't know offhand how to do that and you probably are better off using EMM386 instead, as previously suggested.
