First post, by Splinter
There is a similar thread on this subject by someone else, but I couldn't find it.
Installed on Win 98 SE using the last reference drivers 3.01.00 and DX 6.2.
Dx Diag fails or freezes and any glide games wont run or cant see the card.
I've tried the card in three different Win98 machines and different drivers with the same results.
Maybe it really is faulty.🙁
http://www.compufixshop.com
Main rig Ryzen 2600X Strix RX580 32GB RAM
Secondary rig FX8350 GTX960 16GB RAM
Reply 1 of 9, by PhilsComputerLab
http://www.philscomputerlab.com/ms-dos-game-demos.html
Grab the DOS Tomb Raider 3dfx demo. Run setup and disable sound (just in case to avoid any mucking around) and run it.
It should just work, doesn't need any driver. Try in MS-DOS mode as well.
Reply 2 of 9, by Davros
just to be certain have you tried a dos glide game (in real dos not dosbox and not in a win9x dos windows)
edit: ninja edited
Reply 3 of 9, by Splinter
Will try both those suggestions tomorrow and thanks 😀
Reply 4 of 9, by Splinter
All efforts to to get a game running, even in Dos have failed.
I have to put it down to a dud card and luckily the seller is being very reasonable by offering a refund.
Heck, it happens!
Thanks for your help anyway.
Reply 5 of 9, by CryoSID
Did you try to cleaning the card's pins? It could be just dirty.
Reply 6 of 9, by JaNoZ
Could be the caps bad.
heat up the card in advance.
No contacting QFP legs?
Reply 7 of 9, by AidanExamineer
What's the 2D card you're using it with?
Although it's probably academic at this point, if you've returned it.
Reply 8 of 9, by Logistics
Its not the clearest pic, but a few of the pins on the TMU look goobered. Might need to get in there with a magnifying glass and a razor or needle and make sure they aren't touching.
Reply 9 of 9, by Splinter
I still have the card and forgot to mention that, in driver properties, in spite of newer drivers ie, not the ones Windows wants to load, it always says 'no drivers have been loaded or are needed for this device.................' etc etc
