First post, by anthony
I'm trying to run gus max thru external pci-isa bridge it8888. gus is visible on it's address space, but don't respond to configuratiun commands, thus i hear no sound. gus responds ok on other motherboard. on this external bridge awe64 and tropez plus runs ok on identical dma irq and io. pci registers configured ok. it8888 is able to work with gus max
command that i'm try to init gus cs4231 is 42h to port 326. after that SBHE signal becoms high, but codec no initializes
any ideas pls.
