First post, by CobraA1
CobraA1
Offline
Whenever I try to connect with Detroit using the DosBox virtual modem, I keep getting an "MODEM NOT INITILIZED" error in Detroit.
Here are the commands it sends:
CONFIG:Loading settings from config file dosbox.conf
MIDI:Opened device:win32
Read from B 0
Read from E 0
Read from B 0
TX add A
TX add T
TX add Z
RX add A
RX add T
RX add Z
TX add
Modem Sent Command: ATZ
RX add
RX add
RX add O
RX add K
RX add
RX add
TX add A
TX add T
TX add E
TX add 0
TX add
RX add A
RX add T
RX add E
RX add 0
Modem Sent Command: ATE0
