Which boxes to build?
First post, by Thraka
I'm redesigning my retro machines and I think, like others in this forum, I may be opting to have two separate machines instead of one. I know my wife doesn't like it, but it's what I think I gotta do 😉
For DOS gaming, is a high-end 486 the best way to go? Is there a real case to have a Pentium 1 over the 486?
Once you get to Windows gaming, it seems that a Pentium 2 or 3 could be used over Pentium 1 and would give you a larger range of Windows gaming from the 95' era to just about the XP era. Or does the Pentium 1 actually have value in this space?
Reply 1 of 16, by leileilol
Quake and........ Maxis' early 3d games? 😀
Reply 2 of 16, by Thraka
Quake is easily playing on the 2nd box, the windows machine. And you get the fancy GLQuake too.
Reply 3 of 16, by Skyscraper
DOS version of Raptor and the original version of Tyrian... but yea both games can be played in Windows.
Reply 4 of 16, by tincup
Seems like a plan to me. The 486 not only takes care of the early low-spec stuff but will handle pesky cpu-cycle games - ones that run fine in a dos box in Windows but run too quickly. The W9x box is then free to target whatever sweet spot you're looking for - P2/P3, and will run later high-spec dos games in a box well enough.
Reply 5 of 16, by leileilol
No need to Pentium for those really, or even use a high end 486 for the former
Reply 6 of 16, by chinny22
Pentium 3 with ISA slots will happily cover just about anything that breaks in XP down to Dos games that aren't speed sensitive.
Dos games that are speed sensitive will depend on what the games actually expecting MMX Pentiums seem to cover a fair range by disabling cache, etc.
486 isn't really that flexible for wide range of older games, but they are lots of fun to tamper with 😀
Reply 7 of 16, by PhilsComputerLab
Pentium, especially Super Socket 7 platform always gets my preference. It's simply more flexible than a 486. Also easier to work with, faster at the top end, better suited for Windows, BIOS updates, good documentation, AGP graphics cards...
Reply 8 of 16, by Thraka
Can you tweak the MMX to work fine with the old speed sensitive 486?
I have a ali5 mobo with agp, PCI, Isa, and 266 MMX. Should I just use that as my 486?
Reply 9 of 16, by ncmark
Another vote for pentium I over 486 here. In my opinion most of the pentium boards were of better quality. Most still had jumpers for the multiplier so you an still downlock it if you really wanted to.
For a VERY long time I looked at 486 boards on ebay before deciding it just wasn't worth it.
Reply 10 of 16, by tincup
2 machines is perfect. The 486 is ideal for speed sensitive games - no need to fuss with disabling cache or underclocking the CPU. The 496 stands as it is, and the P2/P3 picks up the load of mid-late 1990s games, and high-spec dos. If anything,the main issue becomes one of which video card or which audio card....
If the OP has parts to assemble two machines he's in great shape. The tricky part is stopping at two... 🙄
Reply 11 of 16, by PhilsComputerLab
If the BIOS has options to disable L1 and L2 cache you are set!
L1 AND L2 off = 386 DX
L1 off but L2 on = 486DX - DX2 depending on chip (MMX is fastest, Pentium average, AMD slowest)
Reply 12 of 16, by Thraka
Is there any benefit from using a powerful MMX chip over a P1 166 for example? What games would benefit from it that I wouldn't be able to play on the alternative P2/P3 machine?
Reply 13 of 16, by tincup
Why all this discussion? The OP can do two boxes - 486 *AND* Pentium. He's got it covered. No need to talk about cache and under clocking. What's going on here?
Reply 14 of 16, by Thraka
Because this is a discussion forum? 😉
Nah I just want to explore all my options. 😀 For example, I don't have a socket 3 PCI board, but I have a few P1 PCI/ISA boards. I may start looking for a socket 3 PCI based on this discussion but I don't know yet...
Reply 15 of 16, by tincup
haha! yes of course.
Reply 16 of 16, by tayyare
Of course it doesn't necessarily mean that it will work for you, too, just because it is working for me but what I have is:
- Main: Core2 Quad 9550 - GTX 560 1GB - 4GB - Onboard Sound - Windows 7.1
- Secondary: AMD Athlon 64 3200+ - Radeon 3600 512MB - 3GB - Audigy2 ZX - Windows XP and Fedora
- Retro Modern: Pentium III 1000 (cop.) - Geforce2 MX400 64 MB and Voodoo2 SLI - 512MB - SB AWE64 Gold and SIMMCONN/32MB - Windows 95 and Windows 98
- Retro Old: Pentium MMX 233 - Voodoo3 PCI 16MB - 256MB - SB16 and NEC MIDI board - Windows 95 and MS-DOS 622/Windows 3.11
These four give me all the flexibility I required, though I should admit I don't need to run very ancient (pre 1990) DOS games or applications, as well as the very modern ones (after 2011-12).
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
