First post, by b_rros
Hi,
I used some parts I had and built a AMD DX4 100 in a PCI motherboard, for what I could see it's a SOYO 30H-B2 (???). I was hoping to use this computer to play DOOM and DOOM 2.
The specs are:
AMD DX4 100
32 MB of RAM
AWE32 CT3900 with a Yamaha DBXG50 daughterboard
Diamond Stealth 64 PCI video card, 2 MB of RAM and...
IBM Microdrive as a hard drive, I had one of those CF to IDE adapters and since the microdrive was the only CF card I had I used it as my primary disc.
The thing is, the computer is slow, DOOM slows down, a lot. Is the microdrive causing the slowdowns? Maybe it's not fast enough to be used as a hard drive.
Or maybe something else, some card or bios setting?
Here's some pics and some Speedsys tests
