First post, by dacow
- Member
Hi Guys,
I remember reading somewhere about old AT power switches having live 240V's (Australian) line connected to the switch but my googlefu is failing me.
Context: I have an old AT power supply that came with some gear I bought a while ago. I figured I could just use power supply as a test PSU for some old boards on a workbench. The power switch has a switch and then four wires going into the PSU. The connectors on the switch and where the wires are connected to are exposed and I recalled that someone mentioned it's quite dangerous to have those open because you could get electrocuted? Should I tape up the connectors or something if I'm to turn on and off the PSU from the switch? Or was this only a particular model of case that had a bad designed switch?
Kind of looks like this: http://product-images.highwire.com/4044688/90 … 6ef1da18dfb.jpg
