First post, by ratfink
Here's a result that puzzled me.
System 1 [now defunct]:
dual athlon 1600mp
wildcat vp990
windows 2000
santa cruz
2gb ecc ram
with vertical sync on: 3895
vertical sync off: 6793
System 2:
p4 2.8ghz with HT
wildcat vp870
windows 2000
m-audio card
256mb non-ecc ram
with vertical sync on: 3916
vertical sync off: 7356
The VP990 is slightly slower as I recall from my own testing, than the 870.
Non-ecc ram should be faster - they are both ddr266 iirc.
I assume sound cards are irrelevant to the test.
3dmark2001se is not multi-threaded I assume, but the view seems to be that it's cpu-dependent.
I was expecting a 2.8ghz p4 to be a lot faster than an athlon 1600mp, but the improvement is less than 10%.
The athlon might be running background processes on one cpu, and the benchmark on the other, but that seems unlikely to explain this. Insufficient ram seems a bit unlikely, wouldn't 3dmark crash?
edit:
turning HT off in the bios gives me 7810, which is better though still only an overall change of 6800->7800 for a near-doubling of cpu rated speed
Or is it just that for these cpu/gpu ranges, the gpu is having proportionately more effect - so maybe 60-70% of the score is due to the gpu [say 5000 in this case] and the remainder is down to the cpu [changing from 1800 to 2800, which is more believable]
