First post, by MrEWhite
I have a Turtle Beach Montego II card. I installed some drivers I found on CNet and I get this error. Is there any fix?
Reply 2 of 14, by MrEWhite
AidanExamineer wrote:
Well if you got the driver from CNet it was almost certainly just a zip file full of adware. 😉
http://support.turtlebeach.com/entry/57741307 … =577413070&Msg=
I found that link. Do you have the 2046 drivers, or can you find them?
Doing the Dorect Download only downloads the main file.
http://download.cnet.com/Audio-Drivers-Voyetr … 9_4-107680.html
Click Direct download.
I really can't find the version number.
Reply 3 of 14, by PhilsComputerLab
It's a documented bug. I can't remember the fix but it involved making a change to the installation file. Google for this issue and you should find an answer!
Reply 4 of 14, by soviet conscript
interesting. I had this issue with a monster MX300 that uses the same chip. I assumed it was because I was installing it in a computer that used a riser card but I got that same error regardless of the PCI slot I used. Put in a SB Live! and it ran without issues.
Reply 6 of 14, by PhilsComputerLab
MrEWhite wrote:
Anyone know where I can find driver version 2046?
On my website: http://www.philscomputerlab.com/aureal-vortex-2.html
I noticed that TB didn't host them anymore so I put them up on my site. I always use the latest reference drivers however.
Reply 7 of 14, by MrEWhite
Those really didn't really work for me. I still got the bug. I'll try the Dell installer.
Reply 8 of 14, by swaaye
Vogons Drivers has everything. Don't use 2048 because they are quite buggy. Use 2041.
Also, it often helps to search this forum. The link you found for the inf tweak should fix the PCI bus detection quirk. I know it's necessary for newer Intel (810+) and nforce chipsets.
Reply 9 of 14, by MrEWhite
I couldn't find it on Vogons drivers.
And the drivers I linked don't work.
Reply 10 of 14, by PhilsComputerLab
What is buggy about the 2048 drivers? I haven't noticed any issues so far.
There is a bug with the TB drivers and Incoming. It will freeze the game after a certain level. Apart from that I haven't noticed anything.
Reply 11 of 14, by swaaye
Some A3D games have partially reversed stereo. Elite Force for example has some sounds placed backwards. The main draw for 2048 is the EAX support but it is poor quality so not much of a loss. They were actually beta drivers AFAIK.
There are 2050 drivers too but they have the same problems.
Reply 13 of 14, by PhilsComputerLab
Interesting! That sounds like a pretty bad bug 😀 I will keep an ear on this in the future.
Reply 14 of 14, by MrEWhite
Fixed it, I accidently removed the whole line instead of the ; me being a idiot as usual :p
