First post, by SpeedySPCFan
- Member
Fantastic, my first post is about help. :v
Greetings, I'm trying to build a retro computer for playing games incompatible with Windows 7/DOSBox and/or to play them on their native environment. This is what I have so far for the computer, and where my issue lies:
Motherboard: Intel Pentium E139761(It was listed as that, looks a lot like a SE440BX-2)
Processor: Pentium II 333MHz
Sound Card: Creative Ensoniq AudioPCI (I prefer it over the SB16. Yes, I'm a heretic)
RAM: 512MB (assuming my 512MB stick works, otherwise I may just end up with 256MB)
OS: Windows 98 SE
2D Video: Matrox Mystique 220 PCI (I was going for Millenium 2, but couldn't find one at a good price that wasn't damaged)
3D Video: Voodoo 3 (preferably AGP, going after one with S-Video)
And those video cards is my issue. According to this post:
But, a Voodoo 3 will not work that way, since it needs no other card to work, it implements a 2D chip. You can still get a PCI card and have it coexist with another AGP card, but it can get messy. First off, you will have to initialize the card you want to use each time through the BIOS. There is usually an option which is kinda like this : "PRIMARY VGA BIOS" and you will have to pick PCI or AGP.
My question is, will I run into any issues if I try and use both a Mystique 220 in PCI plus a Voodoo 3 in AGP? If so, are they so major that I should change my build plans? Thanks!
Musician & music gear/game reviewer.
MIDI hardware: JD-990, SC-55, SC-880, SD-90, VL70-m, Motif ES, Trinity, TS-10, Proteus 2000, XK-6, E6400U
