First post, by Mealeater5000
Hello,
I am attempting to use the AVI Recording function in DosBox (CTRL+ALT+F5), and after the video reaches 2GB, the recording overwrites itself and becomes unusable. I have also attempted to do an SVN build off of SourceForge and it does not even attempt to record (as in I press CTRL+ALT+F5 and play DOOM for a little while, and then check and there is no video in any directory). I used the SVN Building Instructions for VC++ 2008 Express, although I do not have ZLIB or LIBPNG's libraries installed. I am beginning to wonder if this is part of the problem with SVN.
I am using DosBox 0.74 to attempt to record, and I would appreciate any help on how to get the recording function to work. I am also using an NTFS filesystem, so I can record files over 2GB. The game goes into a state of extreme lag after the recording hits 2GB as well. This has been noticed on Windows 7 Professional 64 and 32 bit.
Mealeater5000
