First post, by y2k se
- Member
I have a system running on an ASUS P2B (440BX chipset). Connected to the primary IDE channel is a Western Digital 80 GB hard drive. I have DOS 6.22/WfW 3.11 and Windows 98 SE dual-booting. I currently use Clonezilla to image/restore the drive to a network share.
I acquired a second Western Digital 80 GB drive and wanted to setup a RAID 0 array using a Highpoint RocketRaid 404 controller. However, Clonezilla is not able to see the RAID array on the controller, so I'm not able to restore a image to the array. Also, I would not be able to backup the array.
Is anyone aware of alternative software that would be able to see the RAID array? It would also need to support imaging a drive to a network share or CD-R (the machine has a CDRW drive installed).
Tualatin Pentium III-S 1.4, ASUS TUSL2-C, 512MB RAM, GeForce 4 Ti 4200, Voodoo2 SLI, SB Live!, 3Com 3C905C, 80GB IDE HDD, Dell 2001FP
P233MMX, Intel LT430TX, 64MB RAM, Sierra Screamin' 3D, AWE64 Gold, 3Com 3C905B, 40GB IDE HDD, Viewsonic A75f
