First post, by djdavedave
Good afternoon,
I need to copy some values in DOSBOX Windows as the attached document "Picture 1", to put them in excel file.
The attachment Picture 1.png is no longer available
But I cannot open a window on the DOSBOX Window as the attached document "Picture 2", to select and copy my values.
The attachment Picture 2.png is no longer available
Can you indicate which commande line, I should add into the configurationfile for DOSBox 0.74, or if you have an other solution.
Regards
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
You can't.
Don't use an emulator created for games, for anything serious.
Water flows down the stream
Reply 2 of 2, by djdavedave
Thanks, and which other software can I use ?
