borgie83 wrote:
I've tried reinstalling DirectX and the Nvidia drivers several times but it didn't make a difference. I also just today attempted to reinstall the Via 4in1 drivers but received problem after problem resulting in me having to reinstall Windows 98SE. I then received problems with the 4in1 drivers again after the installation but this time avoided a reinstall by booting into "safe mode with command prompt" and going to the Windows\Command directory and entering "scanreg /restore".
I have had some progress though which is great. Went into device manager and updated the "VIA CPU to AGP controller" under "System Devices" with the Viagart.vxd driver from the 4in1 4.35 drivers. Ran another 3DMark 2001SE benchmark and this time got 6385 points. A massive difference!
Looks promising. At 6300 vs 6500 that's probably on the rest of the system.
EDIT: I have tried the card with my Intel SE440BX-2 board combined with a P3 1Ghz cpu but got very similar results as my other TI4600's.
Absolutely as it should be - the Ti 4800 is identical to the 4600 aside from the gimmick of AGP 8x support (which various reviews/tests from that era, and even later, consistently demonstrated to have almost zero measurable impact on performance; by the time AGP 8x was a "needed" feature, PCIe was well on its way to global domination).
Regarding cooling, I wouldn't say the case has great cooling but it's efficient enough. With your Win 2000/XP question, my Pentium 4 Win XP rig is out of action at present unfortunately so can't test that sorry.
I meant 2000/XP on the system having problems - was basically trying to come up with ways to get Win98, the driver cocktail, etc out of the picture and another OS install would certainly be one path. It sounds like, if you've got it running at 6k+ scores, the remaining difference is probably run-to-run variances (remember that Futuremark has openly said the margin of error for 3DMark is something like 5%), the board itself, disk, etc limitations. So basically I'd say you've got it working unless you experience instability in games/applications with the configuration you have now. 😊
