First post, by kixs
As the title says... I lift the lever up and there is almost no movement of the upper area of the socket. The lever goes up quite "heavy" and even if slowly lifted to the end the socket won't loosen 😕 I tried several times and nothing. Don't want to break anything 😲
Any tips?
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 1 of 2, by n1mr0d
Lift lever + use monkey wrench on the socket and wiggle it around?
VooDoo Power Asus CUBX-E 440BX PIII 1.4GHz GF4 Ti 4600 Voodoo2 SLI 12MB SBLive!+Drive SB16 CT2230 + NEC XR385
Nostalgia pc Vtech Laser Slimline DX4-100 16MB Acumos AVGA1 AWE32 CT3980 Roland MPU 401 MT32 SC88
Reply 2 of 2, by kixs
I dont' have a monkey wrench at hand. But I don't think there is enough space around the socket to get a grip.
Anyway... I lifted the lever to the end and got the CPU out quite easily. The sliding part of the Socket moves about a 0.3mm when the lever is up. I guess it's enough to insert and remove the CPU.
Actually watching the socket while moving the lever reveals that only the inside of the socket moves about 2mm in each direction, while the outside looks like it's stuck and moves just about a small part of mm. Inner part works, outer part doesn't.
Now onto fixing the keyboard connector line on the backside of the board.
