First post, by obobskivich
- l33t
I'm planning to re-do my Willamette P4 as a Win98 box, since the board has worked well in 98 in brief testing, and I no longer have need for it as an XP machine. However I can't decide on a primary 2D/3D card, so I figured I'd come and ask you all. 😀
The basic specifications:
- Asus P4B-LA motherboard (1.5V AGP slot)
- Pentium 4 2GHz Willamette
- 512MB SDRAM
- Sound Blaster Live!
- Voodoo2 12MB
I have two cards on-hand that I'm considering:
- GeForce FX 5800 Ultra. Reasons for: it can support Forceware 45.23 and somewhat older, it's powerful enough to run high resolution and high AA/AF with a lot of older games. Reasons against: I've observed Forceware 45.23 not properly managing its fan in Windows XP (but maybe it works in 98?), it uses lots of power, it takes up two slots.
- Radeon 9550. Reasons for: it's single-slot, should be more than powerful enough to work, and doesn't use tons of power. Reasons against: I have no idea what driver/application support for this card is like in 9x.
I'm also thinking about a Matrox G400 (which would have to be purchased), based on the bits that I've read about them. I know it would be a performance loss against the 9550 or 5800U, but I don't think that's likely to be a problem for this build.
In regards to the "what games would you like to play?" question - this machine is mostly there to catch whatever falls through the cracks from XP, and can't achieve good performance in DOSbox, as well as supporting the handful of old Glide games I have (like Nuclear Strike).
So with that in mind, and of those three, or another option, what would you pick, and why?
Finally, a 3dfx question: does mismatched SLI have any hope of working? I have a Creative Voodoo2 12MB, and I have not seen one for sale in quite a while (I do look, from time to time), however there seems to be no shortage of other branded cards on ebay at any given point. So I'm curious if I were to just snag another 12MB card, what hoops would have to be jumped through to enable SLI between them? And is it even worth it for the performance/resolution jump?
