First post, by Robin4
- l33t
Some months ago that i was some what busy on the NEC V20 Turbo XT, i had you guys letting know that i got a pile of free computers i had picked up that day... I made that post on `Bought new hardware thread`..
There was also that Vtech Laser Turbo XT/3 8086 i got for free.. I hadnt really plans for it, because i found out that i didnt can use that case with an other XT motherboard.. Because laser back in the day made this board proprietary and so only usable with that included case.. That control panel / reset / LED display only works with that included motherboard.
So yesterday i was searching on the internet, and found the original user manual / maintance guide for this Laser Turbo XT 8086/3 system.. I really was relief to found that one.
Suddently i got some brainstorming.. I knew the Laser is a 10Mhz machine..
But in the past, i`d always thought, that my originally NEC V20 i was working on a 12Mhz clock speed in turbo.. But today i had the idea to check all the V20 boards i own.. And found out that they actually are 8Mhz versions of processors.
Now these systems are generally used to play these old XT style games on till the year 1990 or so.. (the later games, i do have later (when its finished) an 286-12 for it available.
I know on not turbo mode they actually running on 4.77 mhz. And that just the right speed to run the previous started (first XT games on)
But on the usefulness of the turbo mode i really like to know if 10mhz isnt just to speedy? Or 8mhz just some what to slow?
Actually i really like to make both (the laser turbo XT/3 8086, and my custom made NEC V20 running like the same processor speed on turbo mode..
I dont know how the Speed display is set on the LASER system( but i dont see any jumper configuration on the back of that pcb) But i think its sensed by the motherboard.
And because the 10mhz turbo setting on the laser system is original, i really dont want to changed that..
