First post, by subhuman@xgtx
Same as title. Is there a way I can disable the EMU8k for midi music in DOS and have the card play it instead through the OPL3 chip? I want to listen to some midis with it using Creative's play.exe but it seems I can't figure out how to set it as the main playback synth the same way you can do within Windows.
Thanks everyone.
Bear in mind I usually post to the forums using my old systems.
Reply 1 of 8, by bristlehog
It can be tricky since OPL3 is not a MIDI compatible device. When you just 'set it as the main playback synth within Windows', many processes hidden from your sight occur. Actually, Windows OPL3 driver uses some kind of an OPL timbre bank to translate MIDI into OPL compatible data.
I am not sure Creative's play.exe has this kind of functionality. If you point at where to get it (the PLAY.EXE), I will look into it further.
Meanwhile, why wouldn't you just use my PX player for your purposes? If you select SBAWE32.ADV driver, it will play through EMU8000; if you select SBP2FM.ADV or WSS.ADV, it will play through AWE32's OPL3 chip. Although, PX player might be incompatible with some (seemingly rare) MIDI files.
Here you can get fantastic wallpapers created by a friend of mine: patreon.com/Unpocodrillo
Reply 2 of 8, by borgie83
Checkout this thread which I started a little while back.
SET MIDI AUTOEXEC.BAT Question
Reply 3 of 8, by AlphaWing
I use a program called Midier for playing back midi in OPL-3, in dos.
http://www.pldos.pl/windos/midier.htm
It works fine most of the time, on most cards I've tried it on, and sounds much better then playing them through windows.
You can use it in windows too.
Never had it crash on me in a 9x dosbox.
Reply 4 of 8, by leileilol
There's also an old Cakewalk demo for DOS that can't save, but can still serve as a midi player of some sort. CAKE5DMO.ZIP, posted it on here before
Reply 5 of 8, by Jolaes76
Another vote for Midier. This is the Swiss knife of DOS MIDI players for sure. Works with just about any ISA sound card and beyond...
BTW. the midier.bat launcher file defaults to OPL2 / OPL3 but on an AWE32 with a DB attached and/or external synth attached the following options are also available:
@echo off
sbmidi.exe /3
THIS IS THE MPU 401, ie. daughterboard or external device
OR
sbmidi /2 FOR the EMU8000 (Proteus) synth of the AWE32
sbsim.com
tui.exe %1 %2 %3 %4 %5
sbsim.com /u
sbmidi.exe /u
Using Aweutil to reroute 330 requests to 620 (MPU401 to AWE32 EMU8000) may or may not work.
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
Reply 6 of 8, by subhuman@xgtx
Fantastic. If I have no need to fiddle with Creative's play.exe and the SET BLASTER variables much better then. I will have a look at these players you suggested me.
Bristlehog: play can be found with normal DOS driver packages for SB16/AWE32 cards
OT: Pretty much nothing to do with the topic, but out of curiosity <and probably discussed many times before> but how does an OPN2 actually compare to an OPL3 knowing they are both 4-op chips?
Reply 7 of 8, by bristlehog
OPL3's differences from OPL2 are described in wikipedia article. In my subjective opinion, the most noticeable difference is its ability to perform stereo.
You can easily notice this using only your AWE32 card. Take PX player, grab a MIDI file and first play it using ADLIB.ADV driver, and it will sound monophonic, then play using WSS.ADV, and it will sound stereo (provided your MIDI file is stereo itself).
Here, I recorded an example video.
Reply 8 of 8, by subhuman@xgtx
Ahh, sorry for the misunderstanding but I was referring not to the OPL2 itself but the OPN2 chip that the Sega Megadrive uses (YM2612).
Still, thanks for the info and video you uploaded. It seems that not many composers managed to take advantage of the newer chip.
