First post, by MarineAir
Just Discovered DOS Box...!
Anybody out there ever tried using dBase, ver 5.1 on back, DOS or Windows, with DOS Box...?
I'm thinking there mite be probs with 16-bit .dbf/.mdx files...???
Direct from the Swamps Of Louisiana...
Reply 2 of 2, by JosSchaars
Using a database with DOSBox can be problematic, it doesn't support record locking.
You could have a look at vDos, https://sourceforge.net/projects/vdos/.
One of its uses is DOS dBase, you should also read the section about Harbuor.
