First post, by mOPQatjjIGnZ6ORlY
Apparently my Intel HD Graphics are disrupting Dosbox's full screen mode. Even if I set the full resolution to match the normal resolution it kicks out of full screen and back to windowed.
As a workaround I can change Intel's properties to 800x600 first, but this is cumbersome since their dialog window doesn't fit. Using other output modes within the Dosbox conf does not help.
Laptop
Windows 7 Home
Intel HD Graphics 3000
Anyone else know of a better solution?
EDIT: Turns out it was Asus's on-screen display ("ATKOSD2") after all. Uninstalling will probably work too, but all I had to do was disable it from the "Startup" tab of the "msconfig" program. Then it falls back to the less flashy, yet also less disruptive one.
Reply 1 of 4, by truth_deleted
Show dosbox configuration settings. Also, did you bother to test whether your dosbox setup works on another system?
Reply 2 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
be sure to the output correctly (e.g. not surface)
Water flows down the stream
Reply 3 of 4, by mOPQatjjIGnZ6ORlY
Now the workaround stopped working. Perhaps it only works immediately after the change and rebooting breaks it.
I've tried all the different output values and none seems to make a difference.
Thanks for taking the time folks, but I'm going to go with Virtualbox and Freedos if I ever go back to the game again.
EDIT: One final thought is it could be Asus's on-screen notifications app as it often appears over my full screen games and applications with ugly and laggy results.
Reply 4 of 4, by mOPQatjjIGnZ6ORlY
For what it's worth this also manifests in Windows 10. Closing the Asus OSD apps does not appear to help. It also impacts other OpenGL software. Sadly I haven't found a solution here.
