First post, by konc
I was always wondering what the actual performance gain from tight memory timings is. OK, we all know that for example a lower CL value means a faster module, but how exactly does this really affect overall performance? Sorry if most of you already know the answer, but this was something still undocumented for me. Well numbers is my kind of thing so I found a 256MB PC133 module rated for CL/RCD/RP = 3/3/3, confirmed with memtest etc that it can tolerate 2/2/2 and ran some benchmarks.
This is not about absolute numbers and performance, but about the difference when only changing memory timings on the same pc.
PCP Player & Quake are from Phil’s DOS benchmarks package and the third is 3D Mark 99 MAX. Test system is a PIII 800EB / Via Apollo 133 / Voodoo 3 2000 / Windows 98SE stock. DOS benchmarks were of course conducted in pure DOS mode.
Reply 1 of 3, by PhilsComputerLab
Great job!
I found the same on BX440 machines. At 100 MHz FSB, most, if not all, PC133 modules can handle CL2 and that offers quite a bit of extra performance.
YouTube, Facebook, Website
Reply 2 of 3, by elianda
Due to the caches the gain is much lower than on old machines, such as 486/386.
Youtube Channel
Reply 3 of 3, by noshutdown
this result seems reasonable. on cpus with higher clock ratio like celeron-1.4g, where memory bandwidth is a scarce resource, 2-2-2-5 and 3-3-3-7 memory timing can yield up to 10% difference.
