First post, by zstandig
I'm sorry if it isn't retro enough, but I have an HP xw6200 (made in 2006, netburst era Xeons). It's very fussy with RAM. Now when I first acquired it I noticed that near the south bridge there is a small silvery cylinder on its side and it appeared to be leaking a really thick.
Now, because it booted fine I ignored it..., but as of late it just likes to beep at me. The "beep code" translation of HP machines said that 5 beeps means the RAM is bad. I've tried many DDR2 3200 ECC Registered sticks and the fussy thing just beeped away for each stick of RAM, even the original sticks it came with.
So my suspicions have drifted back to this tiny leaky thing. When I looked for anything on google, all I found were large leaking capacitors that look nothing at all like what I have. I don't expect any sort of magic bullet here, but I'd like to know what this thing is. here's a pic.
Any ideas what it could be and if that one thing could render an entire board inoperable?
Reply 1 of 10, by luckybob
wow, i thought i wasn't wearing my glasses when i saw that...
I can't make heads or tails of anything in the image, can you try again? look for a MACRO setting on your camera, that usually helps a lot with close up pictures.
Reply 2 of 10, by zstandig
I'll try, as you can see, I'm not experienced at all when it comes to photography 😵
- Damn, I can't believe I didn't think of moving my desk lamp before..., anyway, it's a much better image now.
Reply 3 of 10, by RogueTrip2012
That white stuff is silicon glue meant to hold that lil guy down to the board so the 2 legs coming out do not touch.
How many beeps is the board giving you?
> W98SE . P3 1.4S . 512MB . Q.FX3K . SB Live! . 64GB SSD
>Win XP . AMD 960T . 8GB . Q.K2200. SB X-Fi . 512GB SSD . 2TB HDD
> Win XI . i7 12700k . 96GB . RTX4070TI . 512GB NVME
Reply 4 of 10, by smeezekitty
That is a 32768Hz crystal for the cmos clock. And the white stuff is glue.
That is not your problem
Reply 5 of 10, by tayyare
I'm not sure but it looks like the left hand connector is broken (separated from the soldered point). If the schematic on the board is correct, it looks like it should be staying horizontally on the board, both ends soldered. Am I wrong?
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 6 of 10, by zstandig
Okay, that's a relief, I thought it was something serious. Thanks for the clarification. I've checked a bunch of different RAM sticks of the correct type, so I doubt that's the problem unless by some chance they're all bad. But I don't know what else to suspect as the HP site says that 5 beeps means a RAM problem.
I guess, I'll just have to mess with it some more.
Reply 7 of 10, by zstandig
Nope, you aren't wrong at all, in my haste to try to get a better picture of the numbers on the side I lifted it up slightly. But that end wasn't soldered, just glued (at the time I assumed it was some sort of leak because of the way it appeared to be pouring out of it.)
Reply 8 of 10, by devius
Are there two metal legs soldered to the motherboard? If yes it's fine, if one of them is broken that could be a problem.
Reply 9 of 10, by Half-Saint
I'd look for bad capacitors around RAM slots...
Reply 10 of 10, by zstandig
Yep, the two legs are present. I won't have time to fiddle with it for a while.
I don't know if its relevant but for some reason it only detected 2GB of RAM when it had 4GB. Now, it had XP(32bit) on it, so I knew it wouldn't see 4GB, however in every other machine I used with 4GB of RAM and 32 bit XP, it usually showed 3.x GB or so. That surprised me, and still baffles me.
I'd like to thank everyone who commented, I was going nuts trying to figure out what that thing was. Though I still don't know what's up with the RAM, at least I now know that the "thing" isn't the problem.
