First post, by dosmax
Legend's great (and heavily underrated) Unreal engine based Wheel of Time shooter from 1999 basically still works on newer Windows versions except for the QuickTime videos used to tell the story, which play extremely choppy (<1 fps), if at all. The file below contains all that is required to fix this issue.
The fix basically makes Quicktime use the DirectDraw wrapper from Wine for Windows, which eliminates the choppy video playback problem. Tested on Windows7/64.
http://www.mediafire.com/download/io71kxm82zd … icktime_Fix.zip
BTW: A Glide wrapper (nGlide) is recommended for the best possible graphics in this game, but not required.
Reply 1 of 2, by Mastran
Can´t belieeve noone gave you thanks yet, i was preparing a repack for thsi game, and found myself with this shitty QT problem, your files fixed it
¡ MANY THANKS TO YOU !
Reply 2 of 2, by Acleacius
Thanks for your work on this mod/fix !
Just got the link from reddit, looking forward to trying it.
Edit: Worked great, you ROCK! 😀
