First post, by ynari
I'd like to run Tie Fighter (first CD edition with iMuse) with all the sound options, and a joystick - what's the best way to run it natively? I have an S3 Virge DX for SVGA graphics, an AWE32 for digital sound, and an MT32 connected to the AWE32 for MIDI. I also have a USB T16000M, but that's such an arse to get running in DOS I think it's better to get an old analogue stick and go native. I'd prefer not to use DOSBox.
Question is : what's the best way to control Tie Fighter and get it all working with sound? The cable on the AWE32 has a female gameport port and MIDI in and out 5 pin DINs (originally from an SB Pro!). I can see from the specs that this should work with both a joystick and MIDI, but MIDI out appears to share pins with ground for joystick buttons 3 and 4 - is that a problem?
If I get a Force Feedback Pro, will it work with MIDI at the same time, and how much advantage will Tie Fighter take of it? Is there a better control method?
I also have a spare SB16, a low end PCI soundcard complete with gameport, an SB LIVE and a couple of other nameless soundcards. There's two free slots on my motherboard - one PCI/ISA, and one PCI (currently with a NIC in it, but I could cope with a USB NIC).
Cheers
