First post, by Troix
Hello there 😊
I was wondering whether you could help me concerning the following issue:
I still have the original CD of Maday and one installation of it on my harddisk.
DOSBox tells me that I have to run it under win32 and when I click on the cd drive it says that it is not compatible.
Can you help me?
Thank you in advance and kind regards,
Troix
Reply 1 of 1, by JayCeeBee64
Rank Retired
Retired
You probably meant Mayday: Conflict Earth Troix.
This is a Windows game so it won't work in DOSBox. I also don't have it, so a few more details and info are needed to see if the error message can be sorted out.
What hardware and OS are you currently using?
Was the game installed on your current PC? If not, was the hard drive install copied/moved from an older PC?
Did the game ever worked before? If yes, what hardware and OS were you using at the time?
(To the mods: if this thread doesn't belong in the DOSBox Games/Apps forum, please move it to where is more appropriate 😀 )
Ooohh, the pain......
