First post, by pmcmorris
Hello, I'm trying to get DosBox 0.74 with debugging built for linux. I've found binaries for windows but not linux. I've found instructions for building on windows under MinGW, but I seem to be missing something translating it over to Ubuntu. I can't find any build instructions in the README so I'm just googling and reading random forums and wikis. Is there an official place to find this information?
In summary, I'm doing this:
$ ./autogen.sh
$ ./configure --enable-debug=heavy
$ make
But the resulting build gives all kinds of errors in the make step. I do see this problem in the configure stage, but it doesn't actually cause an error:
checking whether build environment is sane... yes
/home/pmcmorris/devel/dosbox-0.74/missing: Unknown `--is-lightweight' option
Try `/home/pmcmorris/devel/dosbox-0.74/missing --help' for more information
Full output below:
$ ./autogen.sh
Generating build information using aclocal, autoheader, automake and autoconf
This may take a while ...
aclocal: warning: autoconf input should be named 'configure.ac', not 'configure.in'
configure.in:41: warning: AC_LANG_CONFTEST: no AC_LANG_SOURCE call detected in body
../../lib/autoconf/lang.m4:193: AC_LANG_CONFTEST is expanded from...
../../lib/autoconf/general.m4:2590: _AC_COMPILE_IFELSE is expanded from...
../../lib/autoconf/general.m4:2606: AC_COMPILE_IFELSE is expanded from...
configure.in:41: the top level
configure.in:85: warning: AC_LANG_CONFTEST: no AC_LANG_SOURCE call detected in body
configure.in:85: the top level
configure.in:114: warning: AC_LANG_CONFTEST: no AC_LANG_SOURCE call detected in body
configure.in:114: the top level
configure.in:149: warning: AC_LANG_CONFTEST: no AC_LANG_SOURCE call detected in body
configure.in:149: the top level
configure.in:154: warning: AC_LANG_CONFTEST: no AC_LANG_SOURCE call detected in body
configure.in:154: the top level
configure.in:442: warning: AC_LANG_CONFTEST: no AC_LANG_SOURCE call detected in body
../../lib/autoconf/general.m4:2661: _AC_LINK_IFELSE is expanded from...
../../lib/autoconf/general.m4:2678: AC_LINK_IFELSE is expanded from...
configure.in:442: the top level
automake: warning: autoconf input should be named 'configure.ac', not 'configure.in'
Now you are ready to run ./configure.
You can also run ./configure --help for extra features to enable/disable.
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
configure: WARNING: 'missing' script is too old or missing
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether make sets $(MAKE)... (cached) yes
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking for ranlib... ranlib
checking for sdl-config... /usr/bin/sdl-config
checking for SDL - version >= 1.2.0... yes
checking SDL version only being 1.2.X... yes
checking for an ANSI C-conforming const... yes
checking for inline... inline
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for size_t... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking size of unsigned char... 1
checking size of unsigned short... 2
checking size of unsigned int... 4
checking size of unsigned long... 8
checking size of unsigned long long... 8
checking size of int *... 8
checking for stdlib.h... (cached) yes
checking for sys/types.h... (cached) yes
checking for sys/socket.h... yes
checking for netinet/in.h... yes
checking for pwd.h... yes
checking if environ can be included... yes
checking if environ can be linked... yes
checking if dirent includes d_type... yes
checking for powf in libm... yes
checking if compiler allows __attribute__... yes
checking if compiler allows __attribute__((always_inline)) ... no
checking if compiler allows __attribute__((fastcall)) ... no
checking if compiler allows __builtin_expect... yes
checking for ALSA CFLAGS...
checking for ALSA LDFLAGS... -lasound -lm -ldl -lpthread
checking for libasound headers version >= 0.9.0... found.
checking for snd_ctl_open in -lasound... yes
checking whether byte ordering is bigendian... no
checking curses.h usability... yes
checking curses.h presence... yes
checking for curses.h... yes
checking for initscr in -lcurses... yes
checking for initscr in -lncurses... yes
checking for initscr in -lpdcurses... no
checking for target cpu type... x86-64 bit compatible
checking whether x86 dynamic cpu core will be enabled... no
checking whether recompiling cpu core will be enabled... yes
checking whether fpu emulation will be enabled... yes
checking whether x86 assembly fpu core will be enabled... no
checking whether to enable unaligned memory access... yes
checking png.h usability... yes
checking png.h presence... yes
checking for png.h... yes
checking for png_get_io_ptr in -lpng... yes
checking SDL_net.h usability... yes
checking SDL_net.h presence... yes
checking for SDL_net.h... yes
checking for SDLNet_Init in -lSDL_net... yes
checking for main in -lX11... yes
checking X11/XKBlib.h usability... yes
checking X11/XKBlib.h presence... yes
checking for X11/XKBlib.h... yes
checking for XKBlib support... yes
checking for main in -lGL... yes
checking for main in -lopengl32... no
checking GL/gl.h usability... yes
checking GL/gl.h presence... yes
checking for GL/gl.h... yes
checking whether opengl display output will be enabled... yes
checking SDL_sound.h usability... yes
checking SDL_sound.h presence... yes
checking for SDL_sound.h... yes
checking for Sound_Init in -lSDL_sound... yes
checking for Sound_Seek in -lSDL_sound... yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking for mprotect... yes
checking for setpriority support... yes
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating src/cpu/Makefile
config.status: creating src/cpu/core_full/Makefile
config.status: creating src/cpu/core_normal/Makefile
config.status: creating src/cpu/core_dyn_x86/Makefile
config.status: creating src/cpu/core_dynrec/Makefile
config.status: creating src/debug/Makefile
config.status: creating src/dos/Makefile
config.status: creating src/fpu/Makefile
config.status: creating src/gui/Makefile
config.status: creating src/hardware/Makefile
config.status: creating src/hardware/serialport/Makefile
config.status: creating src/ints/Makefile
config.status: creating src/libs/Makefile
config.status: creating src/libs/zmbv/Makefile
config.status: creating src/libs/gui_tk/Makefile
config.status: creating src/misc/Makefile
config.status: creating src/shell/Makefile
config.status: creating src/platform/Makefile
config.status: creating src/platform/visualc/Makefile
config.status: creating visualc_net/Makefile
config.status: creating include/Makefile
config.status: creating docs/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
$ make
make all-recursive
make[1]: Entering directory `/home/pmcmorris/devel/dosbox-0.74'
Making all in src
make[2]: Entering directory `/home/pmcmorris/devel/dosbox-0.74/src'
Making all in cpu
make[3]: Entering directory `/home/pmcmorris/devel/dosbox-0.74/src/cpu'
Making all in core_full
make[4]: Entering directory `/home/pmcmorris/devel/dosbox-0.74/src/cpu/core_full'
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `/home/pmcmorris/devel/dosbox-0.74/src/cpu/core_full'
Making all in core_normal
make[4]: Entering directory `/home/pmcmorris/devel/dosbox-0.74/src/cpu/core_normal'
make[4]: Leaving directory `/home/pmcmorris/devel/dosbox-0.74/src/cpu/core_normal'
Making all in core_dyn_x86
make[4]: Entering directory `/home/pmcmorris/devel/dosbox-0.74/src/cpu/core_dyn_x86'
make[4]: Leaving directory `/home/pmcmorris/devel/dosbox-0.74/src/cpu/core_dyn_x86'
Making all in core_dynrec
make[4]: Entering directory `/home/pmcmorris/devel/dosbox-0.74/src/cpu/core_dynrec'
make[4]: Leaving directory `/home/pmcmorris/devel/dosbox-0.74/src/cpu/core_dynrec'
make[4]: Entering directory `/home/pmcmorris/devel/dosbox-0.74/src/cpu'
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../include -I/usr/include/SDL -D_GNU_SOURCE=1 -D_REENTRANT -g -O2 -MT callback.o -MD -MP -MF .deps/callback.Tpo -c -o callback.o callback.cpp
callback.cpp: In function ‘Bitu CALLBACK_SetupExtra(Bitu, Bitu, PhysPt, bool)’:
callback.cpp:435:47: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘Bitu {aka long unsigned int}’ [-Wformat=]
E_Exit("CALLBACK:Setup:Illegal type %d",type);
mv -f .deps/callback.Tpo .deps/callback.Po
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../include -I/usr/include/SDL -D_GNU_SOURCE=1 -D_REENTRANT -g -O2 -MT cpu.o -MD -MP -MF .deps/cpu.Tpo -c -o cpu.o cpu.cpp
In file included from ../../include/programs.h:28:0,
from cpu.cpp:29:
../../include/dos_inc.h: In member function ‘void DOS_MCB::SetFileName(const char*)’:
../../include/dos_inc.h:543:78: error: expected primary-expression before ‘,’ token
void SetFileName(char const * const _name) { MEM_BlockWrite(pt+offsetof(sMCB,filename),_name,8); }
../../include/dos_inc.h:543:79: error: ‘filename’ was not declared in this scope
../../include/dos_inc.h:543:87: error: ‘offsetof’ was not declared in this scope
../../include/dos_inc.h: In member function ‘void DOS_MCB::GetFileName(char*)’:
../../include/dos_inc.h:544:71: error: expected primary-expression before ‘,’ token
void GetFileName(char * const _name) { MEM_BlockRead(pt+offsetof(sMCB,filename),_name,8);_name[8]=0;}
../../include/dos_inc.h:544:72: error: ‘filename’ was not declared in this scope
../../include/dos_inc.h:544:80: error: ‘offsetof’ was not declared in this scope
cpu.cpp: In member function ‘void TaskStateSegment::Get_SSx_ESPx(Bitu, Bitu&, Bitu&)’:
cpu.cpp:294:37: error: expected primary-expression before ‘,’ token
PhysPt where=base+offsetof(TSS_32,esp0)+level*8;
cpu.cpp:294:38: error: ‘esp0’ was not declared in this scope
cpu.cpp:294:42: error: ‘offsetof’ was not declared in this scope
cpu.cpp:298:37: error: expected primary-expression before ‘,’ token
PhysPt where=base+offsetof(TSS_16,sp0)+level*4;
cpu.cpp:298:38: error: ‘sp0’ was not declared in this scope
cpu.cpp:298:41: error: ‘offsetof’ was not declared in this scope
cpu.cpp: In function ‘bool CPU_SwitchTask(Bitu, TSwitchType, Bitu)’:
cpu.cpp:348:86: warning: format ‘%x’ expects argument of type ‘unsigned int’, but argument 2 has type ‘Bitu {aka long unsigned int}’ [-Wformat=]
E_Exit("Illegal TSS for switch, selector=%x, switchtype=%x",new_tss_selector,tstype);
cpu.cpp:362:49: error: expected primary-expression before ‘,’ token
new_cr3=mem_readd(new_tss.base+offsetof(TSS_32,cr3));
(snip)
Reply 2 of 2, by pmcmorris
Awesome!
That worked. Now I need to learn how to use it. 😀
Thanks very much,
Patrick
