K6-3+/450 overclock tourney: ACZ vs APZ
First post, by lazibayer
I found myself a small project for the holidays. I bought 15 ACZs and 13 APZs and try to figure out their voltage requirements for running at 100x6=600MHz. The test bench:
GA-5SMM (onboard VGA disabled)
256MB PC133 SDRAM
ELSA Gloria Synergy 8MB PCI
Cooler Master unknown model aluminum cooler
Arctic Silver 5 thermal compound
Windows XP SP3
I am too lazy to bench for long so I just run SuperPI for 1M digits for each CPU. Here is the distribution of CPUs according to their minimum required voltage to complete 1M digits:
The attachment k63pvolt.png is no longer available
I don't want to fry them so I mark a CPU as 2.2+ if it can't be stabilized by 2.2V.
Overall among the batch of CPUs I got APZ requires lower voltage than ACZ.
Reply 1 of 36, by PhilsComputerLab
Very cool!
Currently also mucking around with a K6-III+ machine.
YouTube, Facebook, Website
Reply 2 of 36, by noshutdown
nice test, and its awesome to find so many k6-3+s. so far i've only got 3 of them(450acz, 500acr and 500anz) and the price is not very satisfying.
do you still have time with them? i feel that the 3dnow version of quake2(3dnow software renderer) is the toughest test for k6-2/3 cpus, several of my overclocked ones that passed other tests failed in it, so maybe you can give it a try.
does the GA-5SMM have sis chipset? that seems to have inferior memory performance than the mvp3 and ali5, and prevents the cpu from running at maximum load possible. but well, this doesn't mean i would question the fairness and credibility of your conclusion.
Reply 3 of 36, by lazibayer
Too bad I don't have Quake2... Does it work on the demo version?
The reason I chose GA-5SMM is that it's the only board I have that offers voltage lower than 2.0V. Yes it's much slower than P5A-B but the latter can't accept the cooler master heatsink.
Reply 4 of 36, by PhilsComputerLab
I found little performance difference between running a K6-III+ at 400 compared to 600 MHz. Or put another way, if the system struggles with something at 400 MHz, clocking it at 600 MHz is not really making an impact.
I like setting the FSB to 66 MHz and then controlling the multiplier from 2x to 6x for wide compatibility with games.
Reply 5 of 36, by noshutdown
it shall work with the quake2 demo version. unfortunately quake2demo has only a few maps so it can't play the intensive crusher and massive1 benchmark demo.
Reply 6 of 36, by lazibayer
That's a shame... Is there any intensive demo that uses map from the demo version?
Reply 7 of 36, by lazibayer
The cooler and compound
The attachment coolermaster.jpg is no longer available
Reply 8 of 36, by sliderider
How do you read that chart?
Reply 9 of 36, by noshutdown
each number indicates how many cpus are stable at that voltage.
Reply 10 of 36, by kixs
It's easy 😉
He's bought 15 ACZs and 13 APZs CPUS. Almost all work at 6x100=600MHz but the voltage is different. From the chart you can see what voltage is necessary for the cpu to work at 600MHz. You can see that APZ series is better as it needs less voltage.
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 11 of 36, by sliderider
Oh, OK. I was wondering what the columns of numbers were.
Reply 12 of 36, by lazibayer
Thanks for pointing out the confusion. I will edit my post.
Reply 13 of 36, by lazibayer
I tried installing 3.14 demo version, then 3.20 point release, then 3dnow patch. Now I get
ERROR: Couldn't open demos/demo1.dm2
every time launching quake2. Any clues? I am running XP btw, and I tried 95/98 compatibility mode without luck.
Reply 14 of 36, by PhilsComputerLab
I don't think the demo version contains the time demo.
Reply 15 of 36, by lazibayer
The error popped out right after I launched quake2 before I timedemo anything.
I guess quake2 plays demo1.dm2 every time it starts? I am totally new to quake2.
The demo version does contain a tiny toy demo, q2demo1.dm2, but far not intensive to prove anything.
The FPS "jumped" from 41.5 to 41.9 after using 3dnow patch 🤣
Anyway, I need to start selling those chips to fund my other projects 🤑
Reply 16 of 36, by PhilsComputerLab
I also found little benefit with the 3dnow patch. I used the one from falconfly which says "fastest for K6".
What's your next project?
The chip to keep is the K6-III+ 400 1.6V. There is a seller on eBay Germany selling them for 20 Euros. They overclock very well but are fast at the stock 400 MHz anyway. 1.6V is very low and so it runs cool and quiet.
Reply 17 of 36, by Skyscraper
Nice job!
I own four 400 Mhz K6-3+ from the German seller.
Some time in the future I may speed bin them and in that case I will necromance this thread and post the results here.
The first one did 600 MHz at 1.9V so I diddnt bother to test the other 3.
4 is a small sample but better than nothing.
Reply 18 of 36, by lazibayer
Honestly I don't have a clear target of projects... Usually I just grab whatever cheap on ebay when I have spare time and money.
I was trying to break the minimum CPU frequency record for Windows 7/XP, but the xx97 boards I bought do not support ACPI and the 486 boards do not support Pentium OD 😵
Reply 19 of 36, by noshutdown
lazibayer wrote:
The error popped out right after I launched quake2 before I timedemo anything. I guess quake2 plays demo1.dm2 every time it star […]
to make use of 3dnow, you need to change renderer setting to "3dnow software", "3dnow opengl" or "3dnow 3dfx", not just installing the patch.
in my experience, 3dnow software is around 25% faster than generic software, which is also what i use to stress test k6plus cpus. the 3dnow opengl renderer seems to really benefit only 3dfx cards, with nvidia or ati cards there is only around 5% boost over default opengl.
