First post, by dave343
- Member
I have a socket 7 system using the Asus TX97-E board, latest BIOS is installed. 1.12e... Windows 98se runs great on the system, however I dropped in a 2nd harddrive to install Windows 95C. The problem is once 95c is installed, I run the Intel INF utility (Version 2.9), and it installs fine however on reboot with-in seconds of reaching the Windows Desktop, the entire system hardlocks.
Any idea's? Should I try a lower version of the Intel INF's? Windows 98se with the exact same INF utility (2.9) runs great.
