First post, by captainjimsauces
Is it possible to run 2 different dos programs on the same computer? I'm running windows 7
Reply 2 of 2, by Joey_sw
must be noted sharing mount point (directories or images) generally are not adviseable.
its do-able but you may encounter problem when multiple instance of dosbox trying to modify the same file.
-fffuuu
