First post, by notindeed
So i'm trying to run GTA1 in 3dfx mode, which is only available under dos using the gtafx.exe
The problem is, when i try to run the does versions, the game cannot find the cd for some reason and so won't let me play. It is in the D: drive. Does the drive need to be a specific name for it to work with dos applications?
I got the sound working by telling it to run with vdmsound however.
Just so you know, i am using windows xp, sp3.
Any ideas?
I can't really use dosbox as my pc is probably too slow to handle it (can't really manage ultima underwold at a proper speed 🙁 ) so i would prefer the least amount of emulation possible - dosbox is a bit overkill.
Also i have no idea how to get dosbox to use nglide or any other glide wrapper anyway.
Thanks!
Reply 1 of 13, by collector
Jeez, it has been so long that I don't remember exactly where, but VDMS Launchpad had a checkbox to emulate low level access to the CD-ROM drive. If you are using the Launchpad, just look through the settings. Given that this is really more of a VDMS issue, perhaps it should be moved to the VDMS forum.
Reply 3 of 13, by Gamecollector
DOS glide games can't initialize properly in WinXp NTVDM. You must use the DOS/Win9x environment. Or you can use something to translate glide2x.ovl calls to glide2x.dll. DOSBox or Glidos do the trick.
So - your attempts are hopeless.
Reply 4 of 13, by collector
Here it is.
    39.47 KiB
Reply 5 of 13, by Stiletto
collector wrote:
Here it is.
Oh, okay, that's just normal MSCDEX (under Windows XP) then.
do the Fandango!" - Queen
Stiletto
Reply 7 of 13, by notindeed
Hmm, i tried that option and sadly it didn't work.
I also tried doing removing that checkbox option and instead adding SAPUCDEX to the autoexec option as listed here but it didn't help either:
http://www.sierrahelp.com/Utilities/Emulators … d/SAPUCDEX.html
However it seems that SAPUCDEX is a program in itself - so maybe i need to download it? Or is it included in VDMsound?
Update:
So i found SAPUCDEX here: SAPUCDEX by SaPu
It wouldn't work if i put it in the game directory, but putting it in the VDMSound directory worked.
(However i then get other issues - even gta24 gives the issues that no SVGA modes are working (probabably similar issue to system shock where it would work on my 9600 pro fine but requires dgvesa on my x1950 and i can't remember how to configure that atm haha) - but at least the CD issue is solved!)
So, alternatively, how can i get nglide to work with dosbox (or a different glide wrapper). Or can dgvoodoo be used without dosbox?
Thanks! 😀
Reply 8 of 13, by Gamecollector
Install the DOSBox with Gulikoza patch. As the example - this version. Set [glide]/glide="true".
Delete glide2x.dll/glide2x_64.dll from the DOSBox directory.
Install nGlide/other glide wrapper.
Run a glide game in DOSBox.
Reply 10 of 13, by notindeed
Thanks that works!
However there are some issues with it:
When the cd audio track is changing or starting / stopping within game (getting in / out of a car etc) then the game freezes!.
Also i cannot alt-tab or exit fullscreen and other windows also periodically flicker through the screen.
Thanks!
