First post, by King_Corduroy
Hi guys, this is probably dumb but I really don't remember whether or not when you install more RAM in a system you have to configure something special or will Windows automatically see it and know what to do with it like on most modern systems?
In this case I'm talking about Windows 95 on an old Packard Bell 812CD. I just did a fresh install but realized it only has 16MB of RAM in it and it's not the quickest thing on the planet so I'm thinking maxing out the RAM at 72MB would help out a bit. 😜
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
Reply 1 of 18, by JayCeeBee64
Rank Retired
Retired
Go ahead and max the ram out. Windows will see it and make use of it instantly 😀
Ooohh, the pain......
Reply 3 of 18, by smeezekitty
It will work fine. Pretty much all OSes automatically make use of added RAM
Reply 4 of 18, by obobskivich
Yeah Windows will see the RAM as long as it works with the machine - I've seen some machines that will cry and make you go into the BIOS if the installed memory value changes (just enter BIOS -> save and exit and it clears). I think since XP (I say "I think" because I don't know about ME) it may also prompt re-activation if it sees system memory size change. Shouldn't be a problem at all though for Win95 or Win98. I would think stepping it up to 72MB would help it very much as well; go for it!
Reply 5 of 18, by PhilsComputerLab
Try to find out the size of the cache-able area of the motherboard cache. It might be 64 MB but that's just a guess. If you go over performance will suffer. But this should up in benchmarks so make sure you benchmark something before and after. Windows benchmarks, like a game, are quite add for this as they are quite cache sensitive.
YouTube, Facebook, Website
Reply 6 of 18, by smeezekitty
Windows XP doesn't require activation on memory changes.
I think it is only motherboard changes. Maybe on a CPU change or BIOS flash and maybe not even that.
Reply 7 of 18, by raymangold
The only consumer Pentium machines that SOMETIMES contained the 11-bit RAM tag were the 430HX boards (which only used EDO DIMMs). VX and prior are stuck with a crippled cache. I haven't even seen a pentium 1 board to date with the good cache tag...
Since that PBell is not Triton II HX, I have a feeling performance will be hit a *tiny tiny* bit if it goes to 72 MB. Performance gets incrementally worse as the total memory gets farther past 64 MB.
Note: yeah Intel had high end P1 cache controllers that go beyond 64 MB, but you won't find those in PBells or many machines for that matter.
(something funny-- just as intel deliberately crippled the pentiums to 64 MB of RAM-- so too have they crippled the Core i7s to 64 GB of RAM)
Reply 8 of 18, by King_Corduroy
Well that's lucky anyhow since I only had 40mb ram laying around. 🤣
Reply 9 of 18, by smeezekitty
That seems stupid since there were several 486 boards that could cache 128MB
Reply 10 of 18, by Joey_sw
unpatched win9x could use RAM up to 512MB without problem
-fffuuu
Reply 12 of 18, by obobskivich
Here's a detailed article that explains how WPA works: http://www.aumha.org/win5/a/wpa.htm Changing memory can absolutely prompt a re-activation request from the system, and I've seen this happen multiple times in the past. This won't affect Windows 9x, which does include ME, and upon a bit of further reading it appears IA-64 systems do not feature or support WPA. 🤣
Reply 13 of 18, by smeezekitty
hmmm
I have changed memory configurations on XP machines many times without requiring activation
Reply 14 of 18, by obobskivich
smeezekitty wrote:
hmmm
As a single change it may not trigger WPA. Also iirc VLKs don't follow the same activation rules as retail, if that's relevant to your situation.
Reply 15 of 18, by Billyray520
I have one. 😀 It's a Gateway 2000 Anigma board with a 486 DX2 @66Mhz. I have 128 MB of RAM and 256k L2 cache. What I wonder is, can I go from non-parity to parity RAM without upsetting Windows 95? I upgraded my RAM with 128 MB of Parity RAM from 96 MB of non-parity RAM. I have to change a jumper on the mobo to enable parity, which I have been hesitant to do. 😒
Retro stuff owned since new
  • 386 20Mhz 2MB DOS 3.3/PC-MOS 4.0
  • AMD 386 40Mhz 32MB Win 3.11 DOS 5.0
  • 486DX-2 66Mhz 128MB Win 95b
  • PIII 450Mhz 768MB Win 98SE
  • PIV 2Ghz 2GB Win XP/Ubuntu 10
Reply 16 of 18, by smeezekitty
I wouldn't worry. Windows (especially pre-NT Windows) doesn't really care about the low level details.
All the OS worries about is that memory is a big pool where it can address and store data
and that what was previously put at a particular address is still there next time it is read.
My 486 board also says that it supports 128 RAM cached but I haven't had a chance to try it
Reply 17 of 18, by Living
i7 920 only supports 24GB...
Reply 18 of 18, by LunarG
This is only partly true. I've read several reports online about people running 48GB on socket 1366 i7 cpus. When Intel specifies memory limitations for their CPUs they strangely enough seem to take into account the largest ram modules available at the time of release. So although Intel specifies 24GB as the limit for i7 920, it is possible to use more.
This is still less than the 64GB that raymangold mentions though 😉
WinXP : PIII 1.4GHz, 512MB RAM, 73GB SCSI HDD, Matrox Parhelia, SB Audigy 2.
Win98se : K6-3+ 500MHz, 256MB RAM, 80GB HDD, Matrox Millennium G400 MAX, Voodoo 2, SW1000XG.
DOS6.22 : Intel DX4, 64MB RAM, 1.6GB HDD, Diamond Stealth64 DRAM, GUS 1MB, SB16.
