First post, by snowboard71
hi,im playing kyrandia3 with dosbox 0.60(pentium4 2ghz,sblaster audigy,256megramonboard,geforce asus)but the introduction dont start,and if i play without that(start new game)the games work perfectly except the subtitle dialog.they are toooo fast for reading.i have tried to slowdown the emulator but it is the same.please someone help me 😢 .another question:are the voices during the game when appears the subtitles or no voice?i dont remember...thank you.
Reply 1 of 1, by Dark Knight ez
which version? the real CD version, or
the "subtitles only" version (which basicly is the CD version stripped from speech)?
if it is the "subtitles only" version, make sure you set it in Options (or in the install of the game, i can't remember) to NOT use speech.
if you do have it set to use speech when your version doesn't have that, the game won't be able to find any speech and it just skips through the subtitles like mad, since they're synchronized with the speech.
hope that helps.
... // bda. very bda!
... // but only if you turn godo into csah.
