Quake on a P75
First post, by dave343
I've been playing around with a Pentium Classic 75mhz PC for the last week, finally got Windows 95c installed with the driver's etc and thought I'd test out some games, mainly Duke 3D, Quake 1, and Kings Quest 7. All played really well except Quake... it was "almost" smooth, you could tell under heavy action and running around there was some screen tearing and low fps. Duke 3D and KQ7 flew. The system comprised of:
Asus TX97-E
Pentium 75
24MB EDO/Fastpage (it's been a while since I could tell the difference)
S3 Trio64/V2 DX 1mb
Sound Blaster 16 (CT2940)
2.5gb Quantum Fireball 5-1/4 drive
To speed things up I dropped in a Pentium 166 (non-MMX), and swapped the ram from 24mb (4 sticks) to 32mb (2 sticks). I wasn't sure how much of a speed increase I'd see but 95 boots up ALOT quicker, and Quake is exceptionally smooth now, feels like a new game. I do have other CPU's MMX/K6/K6-2 etc but I like keeping the systems I build even across the board, part wise. I hate having a K6-2 system with 512mb ram, and a 1mb video card.
So that was my nostagia upgrade from the past 😀 In today's age where we upgrade from quad cores, to faster quad cores, I think using the system with the 75 for the last week and getting use to that speed, then moving to the 166 under the same conditions and same games, you remember what a real speed upgrade feels like.
Reply 1 of 32, by leileilol
How's the cache?
Reply 2 of 32, by dave343
The TX97-E has 512kb, that I didn't upgrade so it was 512 on both the 75/166.
Reply 3 of 32, by PhilsComputerLab
Nice! Yes going from a 75 to a 166 meant double the performance 😀
Another thing you do with Quake is get a 3D accelerator card like a 3dfx Voodoo.
Reply 4 of 32, by leileilol
*Voodoo2. 'muh bottleneck its pointless' one would say, however the support of multitexturing is a bus congestion ease when it's available 😀
Reply 5 of 32, by dave343
I probably wouldn't stick a 3D accellerator in the machine as it is, maybe a V1 if I dropped in an MMX CPU. I have a K6-2 300/66 CPU waiting for this board, along with 128mb EDO (2x64), but I'm trying to find a deal on a Voodoo 2 or Voodoo 3 PCI. In the mean time, I'm just enjoying the 166 as is.
Reply 6 of 32, by Thandor
If you want to remember how much difference (an easy) overclock meant; try running the P75 at 90MHz or 100MHz and retry Quake. A lot of games run on the P75, but they run so much better on a P90 or P100.
thandor.net - hardware
And the rest of us would be carousing the aisles, stuffing baloney.
Reply 7 of 32, by swaaye
Besides what Leileilol said, Voodoo1 lacks full triangle setup hardware and so has slightly more CPU usage than Voodoo2+.
A P75 isn't going to rock Quake super well but it should be acceptable.
Reply 8 of 32, by Davros
you should really get a voodoo card
Reply 9 of 32, by dave343
I have both a P100 and P120 but felt a good noticeable speed bump, to me anyways was 166.
I couldn't see a P100 making much of a difference but maybe I'm wrong...
I did actually buy a Maxi Gamer Voodoo 2 8mb a few months back, off eBay, but I have been unable to get
Windows to recognize the card. I get nothing, but the pass through cable works fine.
I made a thread on here about he issue, and I've tried the card in a P3 box with the same result. Pass though works fine on this box, and the P3 box but no matter what I try windows can't see it. And it doesn't show up on the list of found hardware when the PC first turns on.
As someone suggested, I check the tiny pins around the V2 chips but none seem stuck together, and I see no broken parts, caps, regulators, etc, and not a single scratch.
Reply 10 of 32, by armankordi
My cousin's old Pentium 3 1GHz Coppermine-T had 256MB DDR and a 1MB Trident 9440... Not shitting you..
I own too many computers to count.
Reply 11 of 32, by noshutdown
i looked up my benchmark results and it recorded that i got 30.5 fps with pmmx-133, and 56fps with pmmx-300(overclocked). i don't have non-mmx pentium though.
Reply 12 of 32, by PhilsComputerLab
All the Quake results one will ever need 🤣
https://docs.google.com/spreadsheet/ccc?key=0 … TWc&usp=sharing
Reply 14 of 32, by Scali
Quake does not make use of MMX technology, so that wouldn't matter.
Reply 15 of 32, by F2bnp
It doesn't take advantage of the MMX instructions, but it sure loves the extra cache available in every MMX Pentium.
Reply 16 of 32, by PhilsComputerLab
noshutdown wrote:
yeah but google is blocked in china because they would not cooperate with chinese government. 🤣
Excel version attached!
Reply 17 of 32, by Scali
Well, if I look at phil's table: https://docs.google.com/spreadsheet/ccc?key=0 … TWc&usp=sharing
I see Pentium 166s and their MMX-cousins scoring within 1 fps of eachother. Which could just as well be explained by a slightly different motherboard/videocard.
So I don't think the extra cache did a lot in Quake (it was probably explicitly optimized hard to fit in the L1 cache of the original Pentium).
Reply 18 of 32, by F2bnp
It does make a difference, especially at low resolutions such as 320x200, which is what you'll be realistically playing at with these CPUs.
Reply 19 of 32, by noshutdown
good job but i test quake a bit differently. i used a more intensive bigass demo which is about 25% slower than quake's builtin demos, and i used winquake which may provide better performance than the dos version, especially on newer computers.
you can also have a look at my tests here:
my socket7 cpu benchmark results
