First post, by Rod Primitive
Rank BANNED
BANNED
I want both CTRL and ESC to act as one button, preferably ESC itself. However, it seems rather difficult or I might just be too stupid.
How do I do it?
Reply 1 of 5, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The ESC key event is triggered by an Escape keypress by default, so you only need to bind an Escape keypress to the CTRL key events. Reset the mapping (by deleting the mapper file) in case you've got things messed up, click on a CTRL key event button, click on the "Add" button, and finally press the Escape key on your keyboard. You can do this with the left, right, or both CTRL key events.
Reply 2 of 5, by Rod Primitive
Rank BANNED
BANNED
Cool, thanks. 😀
Reply 3 of 5, by Rod Primitive
Rank BANNED
BANNED
Need help again. I want to make it so one button act as a turbo button. But currently I can only make it so the button appears to be held down. Can I make it so that the button registers as being pressed rapidly?
Reply 5 of 5, by Rod Primitive
Rank BANNED
BANNED
K
