First post, by Comonier
Hello everybody, i come here to ask if someone already have the same problem...
or... if someone know what must i do to resolve this issue ...
i am using dosbox to play stonekeep, with sound, music, everthing is good, i have a 8.1 64bits windows, with 8 ram gb, processsor intel 7....
i am on ice queen map i already completed faery map and just now ( i dont know why ) all time i get close a npc my game freeze. (and i need to close dosbox)
can someone help ?
Reply 1 of 6, by Comonier
i just get closer of a npc and it freeze
conf of stonekeep
CD=E:\
reverse=0
full=1
sound=E016
music=A009
soundio=220
musicio=388
dma=1
irq=7
video=svga
input=keyboard
vidspeed=medium
#caption_on_
sfx_vol=9
music_vol=9
brightness=0
mouse_sen=5
MOUSE_OPTION=B
#MUSIC_DISABLED
#SFX_DISABLED
Reply 2 of 6, by Comonier
if i start a new game it works normally
the problem is not the dosbox or stonekeep
but is this map i think, or the game after i complet some quests, maps, when i return here, but i back to fairy map to complet quests and retur to here, but now every time i get close of a npc the windows of dosbox freeze, what must i do? i need to close and start again load the game, but still freezing when i get near of npc and i need to pass from him to continue the game. 😢
Reply 3 of 6, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Seems quite similar to: StoneKeep hangs halfway through game
I think the game just has bugs, which might be avoided by restoring from an earlier save point.
Reply 4 of 6, by leileilol
Stonekeep was infamous for its bugs back in the day. There was always that ambitiousbugginess*hype factor to consider with the era, even then, and on most of those, bugs aren't always DOSBox's fault.
long live PCem
Reply 5 of 6, by Gamecollector
Ice sharga following? It's a well known Stonekeep bug.
AFAIR the solution is simple - 180-turn and move backwards.
Reply 6 of 6, by Comonier
I could not solve the problem but I could go through the NPC using the invisibility spells and silence
