First post, by varanoidas
For a long time I have been thinking about taking every (almost) socket 7 cpu I have, overclocking and benchmarking them. Well now I finaly did it. It actually took longer than I thought (few hours yesterday benchmarking and some time today writing it here 🤣 ) I hope you like it and/or find it useful.
Processors used:
https://www.dropbox.com/s/h4tzvn9imz3dhao/IMG … 152529.jpg?dl=0
AMD k6-2 500mhz
Cyrix 6x86 PR200+ 150mhz
IBM Cyrix 6x86 P166+ 133mhz
Intel Pentium 133mhz
Intel Pentium MMX 233mhz
Test rig:
https://www.dropbox.com/s/xkokh04w0jbqk2k/IMG … 151854.jpg?dl=0
https://www.dropbox.com/s/nx37kerhwxet3j2/IMG … 151909.jpg?dl=0
Asus P5A
128mb 133mhz sdram
Ati Rage II+DVD
Benchmarks:
I used Phil's benchmark that contains 3dbench, pcpbench, doom (out of 2134 gametics. Lower is better), Quake
1)AMD K6-2 500mhz didn't work at 100mhz fsb x5 so I used 110mhz x4,5 2.4v. 3dbench: 237.0fps ; pcpbench: 89.5fps; doom 824rt.; quake 58.1fps
2)AMD K6-2 500mhz @558mhz 110mhz x5 2.6v 3dbench: 245fps; pcpbench: 98,5fps; doom: 806rt; quake: 64.7fps
3)AMD K6-2 500mhz @601mhz 100mhz x6 3v 3dbench: 244.2fps; pcpbench: 91.2fps; doom: 896rt.; quake: 60.2fps
4)Cyrix 6x86 PR200+ 150mhz 75mhz x2 2.8v 3dbench: 144.5fps; pcpbench: 40.4fps; doom: 1066rt; quake: 22.5fps
5)Cyrix 6x86 PR200+ 150mhz @166.7mhz 83mhz x2 2.8v 3dbench: 153.4fps; pcpbench: 44.2fps; doom: 1076rt; quake: 24.7fps
6)IBM Cyrix 6x86 P166+ 133mhz 66mhz; x2 3.3v 3dbench: 134.9fps; pcpbench: 36.8fps; doom: 1181rt.; quake: 20.3fps
7)IBM Cyrix 6x86 P166+ 133mhz @150mhz 75mhz x2 3.3v 3dbench: 144.6fps; pcpbench: 40.4fps doom: 1064rt; quake:22.5fps
8 )IMB Cyrix 6x86 P166+ 133mhz @ 166mhz 83mhz x2 3.3v 3dbench: 153.4fps; pcpbench: 44.1fps; doom: 1074rt; quake: 24.7fps
9)Pentium 133mhz 66mhz x2 3.3v 3dbench: 109.3fps; pcpbench: 35fps; doom: 1239rt; quake: 29.5fps
10)Pentium 133mhz @150mhz 75mhz x2 3.3v 3dbench: 118.2fps; pcpbench: 38.5fps; doom: 1116rt; quake: 35.7fps
11)Pentium 133mhz @166mhz 83mhz x2 3.3v 3dbench: 126.4fps; pcpbench: 42.3fps; doom: 1116rt; quake: 35.7fps
12)Pentium 133mhz @190mhz 90mhz x2 3.5v 3dbench: 137fps; pcpbench: 47fps; doom: 1080rt; quake: 39.7fps
13)Pentium mmx 233mhz 66mhz x3.5 2.8v 3dbench: 139.7fps; pcpbench: 49.7fps; doom: 992rt; quake: 41.4fps
14)Pentium mmx 233mhz @200mhz 100mhz x2 2.8v 3dbench: 144.5fps; pcpbench: 51fps; doom: 1007rt; quake: 43.7fps
15)Pentium mmx 233mhz @220mhz 110mhz x2 2.8v 3dbench: 154.1fps; pcpbench: 55.8fps; doom: 906rt quake: 47.8fps
16)Pentium mmx 233mhz @300mhz 100mhz x3 3.5v 3dbench: 166.3fps; pcpbench: 63.2fps; doom: 902rt; quake: 53.4fps
Reply 1 of 6, by PhilsComputerLab
Great effort!
I know how much work you put into these results. Lots of fun though 🤣
YouTube, Facebook, Website
Reply 2 of 6, by varanoidas
Thanks. 😀
Reply 4 of 6, by varanoidas
It should be possible, I will try it tomorrow. Just have a big cooler and bump up the voltage to 3.3-3.5v if you try it 😀
Reply 5 of 6, by Dropcik
What CPU cooler did you use and how did you fit it on there?
Ayy LMAO
Reply 6 of 6, by varanoidas
I used a cooler that was on a socket am2 dual core cpu. It didn't fit very well, capacitors didn't let it sit properly so I used a piece of aluminium between the cpu and cooler. Then it sat very well. I will post some pics of it soon.
