First post, by KT7AGuy
Hi!
I'm running a Coppermine Celeron 600 (66mhz FSB) in an ABIT BM6 motherboard.
Stupid question: Is there any way to underclock this CPU? From what I've read it doesn't appear to be possible.
Thanks!
Reply 1 of 4, by obobskivich
I'm not familiar with that specific board, but in general lowering the FSB will result in an under-clock. You could run into problems if it doesn't enforce a divider though. If you're trying to slow the thing down for compatibility, you may also try disabling the cache (if that option is available). Finally, depending on the board, it may let you select a lower multiplier than whatever is stock for the chip.
Reply 3 of 4, by KT7AGuy
obobskivich, Kamerat,
Thanks for the replies and confirming what I suspected; I'm SOL with this CPU.
Fortunately, both Mendocino and Coppermine Celerons are super cheap on eBay nowadays. I can pretty much select any one I want for ~$5.
Reply 4 of 4, by idspispopd
The lowest you could get with a Coppermine Celeron would be the 533A, or the 800 with an FSB of 66MHz also resulting in 533MHz.
If you don't want to use a Mendocino you could get a PIII Coppermine with FSB100 or FSB133 and underclock it, the lowest would be the 533EB with FSB66 giving 266MHz. I didn't check how cheap those are on US ebay.
