First post, by Nic-93
Im installing dos 6.2 in qemu its saying i gotta insert disk 2 and i did and its saying there is no disk inserted.
Reply 1 of 8, by PhilsComputerLab
Copied version? MS-DOS checks what disk it is.
YouTube, Facebook, Website
Reply 2 of 8, by smeezekitty
What host OS?
Are you tying it to a physical floppy drive? Or using disk images?
Reply 3 of 8, by Nic-93
its a original disk image, and it is disk 2 i inserted to it.
Reply 4 of 8, by Nic-93
smeezekitty wrote:
What host OS?
The VM has been asigned to be a dos system and its a disk image.
Reply 5 of 8, by smeezekitty
Nic-93 wrote:
smeezekitty wrote:
What host OS?
How are you switching disk images? Through the qemu console?
Reply 6 of 8, by Nic-93
uh, not really, is that how? im just placeing it in floppy drive 1 and press enter but noting going on.
Reply 7 of 8, by smeezekitty
I am confused.
If you are using disk images, you have to switch images using qemu console
Use shift+2 to access it from qemu and shift+1 to go back to the main screen.
http://en.wikibooks.org/wiki/QEMU/Monitor#change
Reply 8 of 8, by Nic-93
hmm, is that how it works on the manager when running a vm?
