First post, by Arctic
I wanted to enable Tualatin support and now I am looking for the latest BIOS.
The Motherboard has the ID: SMC67X-2A69KM3KC-00
According to my google search version 06/07/2000-I440BX-SMC67X-2A69KM3KC-00 seems to be still around.
Maybe you guys can help me with this 😀 I can barely find anything on this piece of hardware.
This website seems to have the correct BIOS file. Does anyone here know this website? (wants me to register)
biosagentplus.com/bios/2A69KM31?P…n3oh5keeft4cvi1
Edit:
Just in case anyone finds this helpful.
I upgraded the System:
Before:
Pentium II (Deschutes) 350MHz 512k
192MB SD-RAM PC100 CL3 (3-3-3)
After:
Pentium IIIE (Coppermine) 600Mhz 256k
256MB SD-RAM PC100 CL2 (2-2-2)
- Totally worth it. Now I can play more games on it with a higher framerate.
Seems like the Rage LT is thankful for every percent of extra CPU power.
Reply 1 of 4, by Stiletto
There's this, which you can in theory get for free if you successfully dodge all the adware bundled with their downloader:
http://www.driverguide.com/driver/detail.php?driverid=394197
No telling which version it is though. Filename is 6613r29.zip, contains AWDFLASH.EXE, AUTOEXEC.BAT, 6613R2.9 (16-Mar-2000).
Though given the file date, probably not it.
Make a backup first, and if you brick it, please don't blame me... You should be able to read the string with a hexeditor somehow before you flash it...
I used to have a subscription to DriverAgent/BIOSAgentPlus, it wasn't all that expensive considering how much I was using it at the time. 😀
do the Fandango!" - Queen
Stiletto
Reply 2 of 4, by Arctic
@Stiletto
Thank you!! I have already downloaded it!
Now I also have a Matrox M3D 😁. Can't wait to put it all together.
Reply 3 of 4, by Stiletto
Arctic wrote:
@Stiletto
Which one did you download, the one via BIOSAgentPlus or the one via DriverGuide? Either way, if it worked for you, you should probably reupload it somewhere, having successfully liberated it. 😉
Stiletto
Reply 4 of 4, by Arctic
The DriverGuide Version. I have already extracted the files out of the installer so it should be clean and safe now to flash the BIOS 😀
I can't upload things since I don't have webspace at the moment 😢
