First post, by Half-Saint
I have this Trident 8900B VGA which only has 256KB of video RAM. By adding eight 256K chips I was hoping to get 1MB of video RAM but the system still reports just 256KB. Why? AIDA16 and NSSI do the same so I'm guessing not all of it is being detected.
Reply 1 of 21, by lazibayer
Could you please post a picture of the card and ram chips? I haven't seen a 8900B with 256KB VRAM and 8 empty sockets before. Did you add with 256KB chips? That's probably too big for 8900B to handle.
Reply 2 of 21, by Half-Saint
Sorry, I guess I didn't express myself clearly. The board has 8 chip sockets. I removed the original two and inserted 8 chips that I took from a 286 motherboard.
Reply 3 of 21, by lazibayer
Do you have the model number of the ram chips?
Reply 4 of 21, by tayyare
I'm not sure what the problem is, but just to be sure the basics are there:
For having 1MB with 8 pieces of "256K" chips, you need to use 44256 chips. If you use 41256 (or 4464), then the total will be only 256KB.
44256
41256
4464
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 5 of 21, by lazibayer
These chips have incompatible pinouts. I would be surprised if they can be used on a 8900 without setting jumpers.
Reply 6 of 21, by tayyare
No, it is physically possible to insert 41256 and 4464 chips into 44256 sockets. How does a 8900 will behave when you do, I don't know, never tried. I just wanted him to be sure. I've seen 286 boards accepting both 41256 and 44256 DIP RAMs as main memory (he said he removed the chips from a 286 mobo)
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 7 of 21, by RacoonRider
I have a Trident 8900D with 1MB memory in these chips, shall I take a picture of it for you?
Reply 8 of 21, by Half-Saint
The chips that were oiginally installed are 2x Goldstar GM 71C4256A-80 and I used 8x TMS44C256-80N.
Reply 9 of 21, by lazibayer
Most 286 boards with the ability of taking different ram chips have jumpers to set for the type of memory being used. That's why I ask if the OP can provide photos of his card so we can see if there are similar jumpers to take care of that.
Reply 10 of 21, by Half-Saint
You don't really have to quote everything everyone before you said, makes the post harder to read and the thread longer than necessary. Read my post above yours for clarification regarding which chips I used.
Reply 11 of 21, by lazibayer
OK I shortened my post.
Yes I read your post and no longer ask for chip models. They are in theory compatible. In fact, I was asking if there are any jumpers regarding RAM size selection on your card in my post above yours.
Reply 12 of 21, by Half-Saint
There are jumpers but I have no idea what they do. Here's what my card looks like only different colour, the rest is identical down to jumper config:
http://www.yjfy.com/images/oldhard/video/TMI_4820.jpg
Notice that the card in the picture has 1MB installed? The jumpers on my card are set the same way.
Reply 13 of 21, by tayyare
I found some links with Trident Cards with similar (though not same) layout:
http://museum.ttrk.ee/th99/v/A-B/54450.htm
http://museum.ttrk.ee/th99/v/C-D/54028.htm
http://museum.ttrk.ee/th99/v/U-Z/50459.htm
http://museum.ttrk.ee/th99/v/U-Z/50749.htm
http://museum.ttrk.ee/th99/v/U-Z/50681.htm
Unfortunately, the jumpers are not the same, and no info about RAM size/jumper relation. We can maybe just say that jumpers on your card also are not related to RAM size. To say the truth, this is my experience with one Oak and two Trident cards. I upgraded them from 256/512KB to 512KB/1MB by myself using 44256 chips, and they just started seeing the total installed memory automatically at first boot (all three of them actually reporting total installed video RAM on boot screen).
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 14 of 21, by RacoonRider
Did not find any info on 8900B, but there are other 8900 cards in th99:
http://museum.ttrk.ee/th99/v/U-Z/54493.htm
http://museum.ttrk.ee/th99/v/U-Z/51392.htm
http://museum.ttrk.ee/th99/v/U-Z/50813.htm
http://museum.ttrk.ee/th99/v/U-Z/50105.htm
Maybe that will give you clue as to what jumpers to move. Some do relate to memory size.
Reply 15 of 21, by tayyare
I just realized something from your picture. I was thinking "what the heck are those 5th RAM sockets?" in each memory bank, and realized that they are actually some kind of jumper sets (designated JP1 and 2 - never seen anything like it before), and the lower bank has a terminator or something on it. Probably you are already aware, but I just wanted to remind, because they might definitely be related to memory size configuration.
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 16 of 21, by RacoonRider
OMG my post almost exactly duplicates your, tayyare oO I swear it was not there!
Reply 17 of 21, by lazibayer
Yes the "sockets" are actually jumpers, and yes, they are related to size selection.
http://stason.org/TULARC/pc/graphics-cards/U- … ml#.VNJQNrui7mE
A good photo is better than a thousand words.
Reply 18 of 21, by tayyare
No problem, understood the situation perfectly. It happened to me once or twice. 🤣
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 19 of 21, by Half-Saint
Oh wow! That's great! Can't wait to try this out tomorrow 😀
