First post, by lucky7456969
Anyone know of any links for RV360 chip spec...
It's for a Radeon 9600XT card...
Thanks a lot
Jack
Reply 2 of 7, by lucky7456969
Oh.. Sorry, I meant technical specs, the one that you can program on...
Thanks
Jack
Reply 3 of 7, by obobskivich
You mean like register documentation? AMD has released the 3D Register Reference for R3xx series (which will include RV360), but I'm having trouble finding a working mirror right now. Here's where it should be: http://developer.amd.com/gpu_assets/R3xx_3D_Registers.pdf but it appears AMD re-organized their website at some point and broke the link.
You can find it via Internet Archive here: https://web.archive.org/web/20120210231149/ht … D_Registers.pdf
You might also look at X.org's documentation for Radeon:
http://www.x.org/wiki/RadeonFeature/ (has lots of links to other documentation/projects)
Reply 4 of 7, by Stiletto
The only other document I've come across in the R3xx series is the R350 Technical Manual:
http://www.vgamuseum.info/images/stories/doc/ … 215R9800-11.pdf
Besides this and the other obobskivich mentioned, if anyone ever comes across any others for the R3xx series, please let us know. 😀
do the Fandango!" - Queen
Stiletto
Reply 5 of 7, by Harekiet
Rank DOSBox Author
DOSBox Author
Don't versions of linux kernel or X11 server come with open source drivers for these cards?
Reply 6 of 7, by obobskivich
There are open source drivers for Radeon based on the specifications released; that's documented in my second link (and to further confuse things, AMD also develops their own driver for Radeon, which is not FOSS). I do not think the Linux kernel proper has them "built in" though. 😊
Reply 7 of 7, by leileilol
i think he wants to make a radeon9600 for DOSBox
long live PCem
