First post, by Guest
The Help file says to mount a C: drive, type this:
mount c /home/user/dosprog
This does not work on Mac OSX. I tried it like this:
mount c Harddiskname:Users:Username:directoryname
but it won't work. OSX uses : instead of / but also with / it won't work. What is wrong?
Reply 1 of 9, by Snover
That's a good question. You'll probably have to ask the maintainer of the OS X port -- it's not officially supported, and none of us have PPCs. 😀
Yes, it’s my fault.
Reply 2 of 9, by Guest
Works like a charm for me in OS X (10.2 and 10.3).
What is the error you're getting exactly?
Reply 3 of 9, by Guest
It says: directory does not exist
No matter what I try. But I must do something wrong. I try it like this:
mount c /home/username/directoryname
I also tried with : instead of /
It won't work either...
Reply 4 of 9, by Snover
Um, maybe the directory doesn't exist? 😅
Yes, it’s my fault.
Reply 5 of 9, by MiniMax
Rank Moderator
Moderator
As far as I know, OSX is basically a Unix variant with a grahical frontend. So while you might know your directory paths as Harddiskname:Users:Username:directoryname, I think the underlying operating system still uses the standard Unix notation of /dir1/dir2/dir3.
So the question is in which context DOSBox is interpreting file names? Is there someway you can start a Unix command prompt (a Shell) on you Mac?
Can you use the commands 'cd dirname', 'ls -l' and 'cd ..' to navigate your way to the directory you want to mount?
Can you use the command 'pwd' (print working directory), to see what the OSX/Unix name is?
What happens if you try to mount the directoy from DOSBox using the path given by 'pwd'?
MiniMax
_________________
Reply 6 of 9, by Guest
@Minimax:
Thanks a lot! I tried the Unix command prompt in OSX and the PWD command showed me exactly the right syntax. Now I can mount my drives. Thanks again,
ZACH
Reply 7 of 9, by MiniMax
Rank Moderator
Moderator
Ahh - the power of the command line strikes again!
MiniMax - "As the pen is mightier than the sword, the command line is mightier than the mouse."
_________________
Reply 8 of 9, by Somewhat Damaged
What help file are you using? I can't find any help-file ANYWHERE!
Also, I just downloaded the latest version, and I have no idea how to run it (for OS X). I have tons of old DOS games on CD, but I don't have a clue on how-to run the dosbox program that I downloaded...
any ideas? A link to the "readme" perhaps? Thanks...
Reply 9 of 9, by MiniMax
Rank Moderator
Moderator
The latest and greatest DOSBox ReadMe file, straight from the source.
_________________
