imgmake and format
First post, by legluondunet
Hello,
I would like to create a hdd image with dosbox, but I can not format it, I need help!
This is how I proceed:
1) create hdd image --> ok
$ imgmake windows95.img -t hd -size 1024 -nofs
2) fdisk hdd image --> ok
my dosbox.conf:
[autoexec]
# Lines in this section will be run at startup.
# You can put your MOUNT lines here.
keyb fr
imgmount 0 Dos6.22.img -t floppy -fs none
imgmount 2 windows95.img -size 512,63,64,520 -t hdd -fs none
launch Dosbox:
XsfDFh6aTRGvUIX8yw7Iost6vU3jFjr5t9sHDfG7Kr4=w640-h428
All 2 img mounted, no error message
Now I type:
boot -l a
to boot on the dos 6.22 img, then type:
fdisk
everything ok, Dosbox reboot, I do again a
boot -l a
then
format c:
and I obtain that error message:
invalid drive specification
I don't know why it doesn't work, I did something wrong?
Reply 1 of 1, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Please use the guide at Sample usage of a harddisc image in DOSBOX and lock stock Dosbox. you are using a non standard dosbox version which might or might not have errors.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
