Unknown NEC Board
First post, by Stojke
Does anybody know what this is?
It has an 8pin mini DIN connector, like the one pictured here: http://www.raphnet.net/electronique/tgfx16_us … din8_female.jpg
Reply 2 of 14, by Stojke
That would explain the RAM size, tranzistors and jumpers.
I was hoping it was an MIDI device.
Reply 3 of 14, by shock__
Quite hard to find out ... the silkscreen printings turn up no results on google and the 2 larger NEC chips are generic gate arrays allowing no conclusions on their functions.
Might be a midi card ... or a scanner driver ... or a video processor.
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 4 of 14, by tayyare
Or a part from a medical device?
http://directmedparts.com/mri-parts-coils/ge- … if-2-board.html
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 5 of 14, by Sutekh94
Some kind of Apple LocalTalk or serial adapter for PC? Just a guess, since Apple serial/modem ports from that era are basically the same as the port on that card.
My YouTube | My DeviantArt
Reply 6 of 14, by Stojke
It is interesting how the writing on it is completely useless.
Maybe there is some one who knows what an IF2BOARD means?
Reply 7 of 14, by shock__
Probably "Interface 2 Board" 😁
Other hints given:
Apple LocalTalk adapter: Can probably be dismissed as such an adapter is quite a simple device and wouldn't require those bulky gate arrays - also seems to be using Sub-D jacks on PC cards.
Medical device: not remotely, see the botch caps on the solder side, the board you linked is actually TV/broadcast equipment.
[Z?]
Reply 8 of 14, by Stojke
Looking at the individual components, JRC 723D is an high precision voltage stabilisator, and Nec uPC844C is an quad speed OPamp. I doubt MIDI needs such things, plus there is no component to galvanically separate the connector from the rest of the electronics, which is usually present in MIDI interfaces.
Reply 9 of 14, by Stojke
Cany any one confirm that this is an scanner card?
Reply 10 of 14, by oerk
Can't confirm, but I'm also guessing that this is a scanner card.
MIDI card is pretty unlikely - MIDI uses 5-pin DIN connectors, and it should have at least two of them.
Reply 11 of 14, by tayyare
shock__ wrote:
Probably "Interface 2 Board" :D […]
Other hints given:
The link is from a medical device part supplier and the name of the board is "IF 2 Board". I of course don't know what on earth "IF 2 board" really means. 🤣
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 12 of 14, by keropi
"IF 2 board" most likeley means: InterFace 2 board 🤣
Reply 14 of 14, by Stojke
Holy shit i saw that exact video a long time ago, cant believe its the same card 😁
But everything is indicating its a scanner card, so I think thats whats it gonna be in the end.
