First post, by silverdave
Hi Folks
I am new to this forum, and hoping this is the correct place to go for some quality help from some of you experts.
The computer I am using is HUDL2 tablet (courtesy of Tescos, here in the UK - and China, where I believe it was made). It is running on Google Android Version 4.4.2 KitKat. The Processor is a Quad-Core Intel Atom 1.83GHz with 2GB of RAM.
I have enabled the "Hacker's Keyboard", downloaded from Google Playstore (v 1.37.1419)
DOSBox Turbo was purchased from Google Playstore (v2.1.20)
DB Manager Not Installed.
Now, my main issue is that I am having problems trying to access the keymapper so that I can look at possibly tweaking the settings. When I press Alt, the blue line lights up below the Alt on the actual key, but then when I press F1 nothing happens - the DOS prompt just stays at C:\> (no movement). I read somwhere that I can access keymapper from the command line, but I can't find where this is stored in the system since I mounted the local directory as "/sdcard/Mf/" (Mf is the directory I am using to access my DOS program).
Any help would be appreciated. I am also struggling to get my DOS program (Masterfile PC) to work with both "Alt + Function Keys" and also Shift + Function Keys". It's works OK with Ctrl + Function Keys!?? The Keyboard Layout is currently set to USA, but the problem exists with the UK option as well.
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
Ask the person who you paid money to.
It is not us and I refuse to provide free support for their things.
Water flows down the stream
