can't mount anything
First post, by Newuser
first of all, if i press [alt gr]+[ß] to get a backslash on a german keyboard, nothing happens, so i cannot type a backslash in dosbox, kind of a problem if you want to mount something 😉
then i tried to mount a "root" direcory because i thought this would work without a backslash, for example
mount c d:
but dosbox says "this directory doesn't exist". probably i should write
mount c d:\
but this is a bit difficult without the backslash....
is this a common problem? i use winXP...
Reply 1 of 1, by Guest
ok i must apologise i didn't read the readme completely....sorry for the post
