First post, by paradigmsick
Hello Gents,
I got a question regarding my DOSBox setup regarding serial ports. I have PC with native a serial port (for which win7 has allocated COM1 to) and I set up my conf file to COM2 in the sandbox also, like so...
[serial]
serial2=directserial realport:com1
There is a program that I use which communicates with a very old data logger (via RS232) for which has a batch file configuring the ports through
mode com1:9600,,,, > nul
However the application fails to communicate via the COM port. Running 'mode.com com1' just to see if COM1 is setup it echos:
COM2 not existing in this PC. Running 'mode.com'
It has :
*****PRINTER PORT 1 STATUS******
Port status: [ ]
*****VIRTUAL PRINTER PORT 2 INFORMATION*****
Free for redirection to serial ports
*****VIRTUAL PRINTER PORT 3 INFORMATION*****
*****VIRTUAL PRINTER PORT 4 INFORMATION*****
So it seems that no matter how the conf file is setup it only has LPT1 setup and no COM ports.
Does someone know why that is the case ? Btw, I appreciate and understand that this emulation is not for commercial sw and nor do I want support for that, this is more a fundamental question about setting up COM port no to physical serial ports.
Reply 1 of 1, by Jorpho
Have you tried adding serial1=dummy? Perhaps it does not expect there to be a COM2 but no COM1.
If you have any other serial devices that you can use for testing, that might also be a good idea. (Even a modem or a serial mouse will help.)
